Jet Hot vs Exhaust Wrap - Fuelly Forums
Old 04-16-2008, 05:06 PM   #1
Hey guys. I'm a total newbie. This is only my second post. I would like to start posting more, but I haven't even used my 1st tank on my recently purchased 99 Corolla. I'll start to track my mileage and go from there.
Anyways, I've been reading around and saw some mixed (good/bad) post about exhaust wraps. How would this product compare to the exhaust wrap? Looks interesting. Feel free to post. Thanks. Everyone have a good day.
http://www.jet-hot.com/
99corolla
99Corolla is offline   Reply With Quote
Old 04-16-2008, 05:47 PM   #2
GasSavers_SD26's Avatar
There can be condensation when one uses a wrap that can eventually ruin an exhaust. Jet Hot and other coatings like it kind of help out in that regard in that it's applied to the metal on the inside and the outside.
I think exhaust products like those offered by http://swaintech.com/ are superior in what they are supposed to do, but they don't have the same fashionable look.
Dave
Old 04-17-2008, 02:22 PM   #3
Headshot Zod's Avatar
I'm going to go with Swaintech but I know it is going to be expensive to coat the inside and outside of my 4" exhaust. Thank goodness they are only 4-5 hours away. Hopefully I can "make an appointment" so I can save on shipping.
1992 D250 (BHAF/ASA Modifieds intake) Biodiesel & WVO/
My Truck's Blog
U.S.F.R.A. vehicle # 284
AltWheels.org-2004 People's Choice Environmentally Friendly Renewable Fuel Vehicle / AltWheels 2005 pics#1 #2 / Altwheels 2006 pics#1
I don't do drugs but my truck does.....
Stage III Methanol Injector
Headshot Zod is offline   Reply With Quote
Old 04-17-2008, 03:19 PM   #4
DarbyWalters's Avatar
Swaintech and I did a Mazda Rotary 12A and it did awesome. We did all kinds of coatings...slip coatings, heat dissapating, heat soaking, ect. Stock engine went from 120hp stock to 174hp (stock w/coatings).
Ceramic coating of headers/exhaust definitely helps with "scavenging"
Old 04-17-2008, 05:22 PM   #5
Read up here on real experience.
http://www.theturboforums.com/smf/in...?topic=46435.0
Old 04-17-2008, 05:32 PM   #6
99Corolla,
Welcome to the board and enjoy your stay.
To the question on coatings...
The wraps have one big plus in that they can be fitted in place with out taking the exhaust off and sending it away for coatings.
They do take up more space but the difference is small and they can look ugly if they are poorly done.
The reputation is they can cause exhausts to corrode more quickly and they are also only on the outside of the pipe not on both sides.
The coatings correctly done insulate both the inside and outside of the pipe as well as the attached brackets , plates etc all of which helps.
The items need to be removed , sent away and replaced on return , so it all takes longer.
Prices vary depending on brands and reputation.
The dimensions are in practical terms unchanged and the looks are often improved.
Good luck with it all and post what you find after it is all done.
Cheers , Pete.
GasSavers_Pete is offline   Reply With Quote
belly pan advise please holypaulie Aerodynamics 3 08-05-2007 08:54 PM
LRR tires PDF info GasSavers_Jack General Fuel Topics 11 06-14-2006 06:21 PM
Underbody Tray Design Bunger General Fuel Topics 24 03-05-2006 04:09 AM
Money Back for Energy Saving Appliances! GasSavers_DaX General Discussion (Off-Topic) 0 11-09-2005 04:19 AM
