I've never been more proud of my Geo Metro - Page 2 - Fuelly Forums
Old 05-24-2008, 05:59 PM   #11
88HF's Avatar
freaking right
that woman is right, gots to.
my favorite thread
Old 05-25-2008, 02:54 PM   #12
This solidifies my $200 purchase for my 96 Metro restoration project!!!
Can't wait to get her running!
bigrobrn is offline   Reply With Quote
Old 05-25-2008, 09:56 PM   #13
GasSavers_JoeBob's Avatar
Ah...another $200 Metro...there's still hope. (Casting eyes about for another Metro in need of "TLC"...)
Old 05-25-2008, 10:14 PM   #14
1993CivicVX's Avatar
are the festivas compareable to the metros mpg wise? personally i like the festivas looks more than the geos...
not even close. But swap in a D15z1 and you'll be doing just fine in that Festiva.
three stripes the charm!
Old 05-26-2008, 08:39 AM   #15
really? i woulda thought they would be comparable to the 4 banger manual tranny metros...
Old 05-26-2008, 09:49 AM   #16
See my sig. That's a combined average not the highest or the lowest. My tires are only inflated to 35 psi as well. I'd probably do better if I inflated them to the max like some people here do, but I just don't care for the ride at the higher pressures.
N
nlife is offline   Reply With Quote
Old 05-26-2008, 10:12 AM   #17
Looking at the geo owned by the OP, my festiva is doing better and the only mod I have is a Crane Cams ignition system that I had on hand and decided to use. I am running Amsoil Signature series 0-30 and double platinum spark plugs, but that's it.
The OP has his tires inflated to 65 psi whereas mine are running at 35 psi. The OP would appear to have ripped out as much as possible to get better MPG, while everything that came with my Festiva is in the Festiva.
That's not to knock the OP or his geo, but the festiva (at least in my case) is putting up better mpg's on average than the Geo owned by the OP, even when I had approx. 300 lbs extra weight in my vehicle over the usual two people and had tackled a trip from sea level up 800+ meters.
N
Old 05-26-2008, 10:34 AM   #18
well I know the stock Festiva Epa numbers are considerably less than the metro or VX. The Metro is rated at 43/51 and the Festiva is rated at 30/37, so that's what I was basing on.
The Metros that are notorious for great FE are 3 cylinder, not 4.
Old 05-26-2008, 10:42 AM   #19
I'm not sure that more inflation would help you. Nobody promotes increased inflation more than I do, but I suspect that beyond the point of acceptable comfort doesn't provide any useful improvement -- and certainly nothing worth ill handling tires that won't leave you safely able to maneuver. Inflate them to just under the point where they're uncomfortable.
For me the limiting factor tends to be the maximum pressure of the tires, but I tend to drive relatively heavy vehicles even when I'm driving a small FE car.
Old 05-26-2008, 10:44 AM   #20
I can see that then. The EPA for the Geo is certainly higher than the EPA for the Festiva. I've been pretty happy with the fact that I'm getting about 24% better mpg than the sticker said I should and am really only using the basic hypermiler techniques 40mpg is an easy reality for me at this point. The Festiva sure beats the hell out of my Liberty, just not in the comfort area.
Drinking snake oil... GasSavers_DaX General Discussion (Off-Topic) 2 02-08-2008 05:48 PM
BBC film GasSavers_Richard Introduce Yourself - New member Welcome 5 10-02-2007 03:03 AM
The Future: Compressed Air Hybrid? FritzR General Fuel Topics 6 08-12-2007 04:58 PM
gas log CarNutCertified General Fuel Topics 4 05-23-2007 07:48 AM
I will be bike riding across Iowa kickflipjr People Powered 11 08-02-2006 04:22 PM
