01-13-2010, 11:02 PM
It's cold!!!
I have a 11-15 minute drive, and the aftermarket guage only gets up to 140F.
I have a turbo in the car(OEM), and I have water injection installed pre and post turbo. The intake has a hose attachment that goes behind the headlight. I am thinking about pulling it out and letting it suck air from toward the turbo.
Daihatsu Move pictures 1999
here is a pic of the car. The turbo is above the license plate, and the radiator is on the opposite side.
The top grill is half blocked already(to protect the turbo), and I am considering blocking the other half off too. I will start with those two things, and see how the temps do. If that doesn't work, then I will try to block the bottom half with something attached to the grill, not to the radiator, to prevent too much airflow loss.
Anyone see any problems with this?
01-14-2010, 05:14 PM
Have you checked your thermostat? I don't know your car, but I'd think it should be warmer than that...
01-14-2010, 05:19 PM
The car during the summer hovers around 180 and then the fan kicks on. This is mounted after the T-stat, so don't consider it real engine temp. I think there is just too much cold air over the radiator to get the temps up.
01-14-2010, 07:26 PM
You in Japan? Ah, I see, Mito. Great fun.
They have some awesome small vehicles.
Don't have any suggestions, just wanted to send a shout out because I really miss Japan. Was there from 1990 to 2000.
01-17-2010, 03:03 AM
Hi Joe, you replied the same way to my temps, didn't you.
You should know that small economical engines don't warm up as fast as your big fuel consuming engine/car. You should compare the absolute fuel consumption per time or mileage (mine: 6l/100 km, yours 17l/100km). You will see that your engine really has a lot more fuel burnt that goes up into heat into your engine (approx. 30% goes up into heat loss into the engine). Mine and this small engine doesn't have such a big amount of fuel burnt for warming up the engine. We hardly have enough heat left to heat up the cab.
01-17-2010, 05:24 AM
I've always assumed that a smaller, less powerful engine would heat up faster. The engine has to make the same amount of work since you're going to use approximately the same energy to move a given vehicle; even if it does it more efficiently, a smaller engine might use 50% of its available power to do what a larger engine does on 20% of its power. Plus, the smaller engine has less mass in its block and coolant that it needs to heat up.
01-18-2010, 02:03 AM
blocked the bottom grill, temps seems to be getting there faster, without getting over.
01-18-2010, 05:07 AM
I've done a rough comparison (very rough) between my 1 liter Geo @ 1700 lbs weight, and my 4.1 liter Cadillac at 3800 lbs weight...they both take about the same time to reach operating temperature...if anything, the Cad seems to take just a bit longer.
01-18-2010, 01:01 PM
You guys must be right. Should be approx. the same. I misread also your fuelconsumption Joe, I thought you had a car that consumed 17 l/100 km, but it's 13.
01-18-2010, 05:46 PM
i-DSi, there may be some merit in what you say as well...the cooling systems on each car are designed for the conditions encountered in each car...the Geo has a small grille opening and a shrimpy radiator, whereas the Cad has a very large grille opening and a large radiator. I expect that the engineers who designed both cars designed them for similar warm-up and cooling characteristics, despite the difference in the size of the engines and cars.
