Is Instrumentation Important? - Page 3 - Fuelly Forums
Old 08-01-2006, 02:42 PM   #1
Mighty Mira's Avatar
Originally Posted by ketel0ne
That which is measured, improves.
It works in exercise, tasking, process, time management and almost every other area of life and it works with MPG/FE too.
That's an excellent point, and a true one. The next question becomes "Am I measuring the right thing? Is there a discrepancy between my metric and the overall goal?"
For example, if you run 5000m and choose (for some stupid reason) to get better at it by sprinting, your sprint time will improve. When it comes time for race day and you run a worse 5000m than before because you gained muscle to help with the sprints, you might cry out "Why? But I was lowering my time/distance figure! I don't understand why I can be faster and yet slower!"
Another example might be sales. Say that you decide that you are making $200/day, and you do that by seeing 10 clients. You figure that if you can slot 15 clients into a single day, you can make $300/day. Instead of working more hours, you decide to rush through your presentation. The end result is that you cram more people in, but none of them want to buy from you because they feel like you are pushy, and you haven't answered their questions because they can't get a word in edgeways.
Instantaneous FE metering is a bit different in that respect, but there are still artifacts associated with improving your FE at any given point in time when your goal is to lower fuel consumption over the distances you need to travel. On balance though, there is no faster learning that will take place as with instantaneous feedback.
Mighty Mira is offline   Reply With Quote
Old 08-01-2006, 01:41 PM   #2
krousdb's Avatar
What color is your Civic Compaq?
Old 08-02-2006, 05:23 AM   #3
Compaq888's Avatar
I don't understand how that relates to the thread or anything to do with fuel economy.
Old 08-02-2006, 05:30 AM   #4
Compaq888's Avatar
Here is my strategy.
Accelarate slow. Get into 5th asap. Do some aero mods, overinflate tires, drive behind trucks on the freeways and streets because they accelarate slow and they drive slower than cars most of the time.
Once I get the hang of the cluch I'll start tinkering with coasting, bumpstartig and etc. I still stall the car.
Old 08-02-2006, 08:20 AM   #5
Matt Timion's Avatar
wow
Old 08-02-2006, 08:55 AM   #6
krousdb's Avatar
OK, should I start another thread to find out what color it is?
Old 08-02-2006, 07:42 AM   #7
What color is the civic? Too bad you didn't get a hatch, that means you're already missing the possibility of the best color availiable on the crappy EK (96-00)
Old 08-02-2006, 08:21 AM   #8
I bet it's some ugly color like EBP, eww.
Old 08-02-2006, 08:58 AM   #9
He should've introduced the new car to us but I guess it's top secret.
Old 08-02-2006, 09:26 AM   #10
GasSavers_brick's Avatar
Compaq, would you at least consider getting a vacuum gauge? If you're hung up on aesthetics you can even stick it in one of those A-pillar pod thingys (to each his own). It's cheap, it won't record trip mileage, but it will help you to manage your right foot. I'm telling you, you have no idea how much a subtle variation in pedal pressure makes until you have a device that shows you the effects in real time.
Now the question, "What good does a vacuum gauge do if it doesn't tell me my MPG?" Well, lots. Manifold vacuum is directly related to instantaneous MPG. Greater vacuum = less air flow into the engine = less fuel burned at that particular moment. This gives you a numerical benchmark for how hard you are accelerating as opposed to the "posterior accelerometer" method, which is notoriously imprecise. In other words, you develop a target number to stay below. It helps on the highway, too. Let's say you're just cruising along at 60mph. It's really easy to apply more pressure to the throttle than necessary, thus burning more fuel than you need to. Call it the "quiet killer" of FE. With a vacuum gauge (or ScanGauge or MID or whatever) you can make a game out of seeing how low you can get that needle and still maintain your target speed.
Use it well and your FE will improve quite dramatically. Vacuum gauges go for, what, $20?
'07 Toyota Prius
Text Query vr4Legacy Fuelly Web Support and Community News 3 03-17-2011 01:09 AM
A feature I'd like Fuelly to add to site Keen4Green Fuelly Web Support and Community News 5 05-29-2010 06:25 AM
Reporting capabilities via SMS? hidesertmlb Fuelly Web Support and Community News 4 09-02-2008 12:02 AM
Found another way to save on gas. Compaq888 General Fuel Topics 42 03-16-2006 04:48 PM
Drive 55 SVOboy Hypermiling 15 10-29-2005 11:13 AM
