is Energy savings II motor oil better - Page 2 - Fuelly Forums
Old 07-17-2007, 06:51 PM   #11
Energy saving II motor oil? what exactly is that?
I see that written on about 50 oil caps a day and they are all 5w30, is that what you mean?
I use 10w30 in mine and would like to change to 5w30 next change. I normally burn a quart every 3k miles(120,000+ miles on car), Im afraid I might burn it off faster though, using a thinner oil?
Old 07-18-2007, 06:53 PM   #12
baddog
I am not an expert on energy saving II oil but some cars recommend using it as my 95 corolla does. I believe the theory is that it causes less resistance which mean less friction or something like that. I am not sure if its because the oil is thinner or light but that is the basic idea. I don't know if you should put it in your car if it is not recommended but that would be a good question.
95_corolla is offline   Reply With Quote
Old 07-19-2007, 07:49 AM   #13
brucepick's Avatar
I suspect that Energy Saving II oil is one of those designations they invented years ago while steadily improving oils over the years. I'm sure that any modern API rated oil will be at least as good and probably better FE than the best stuff available 10-15 years ago.
And along with that it looks like thinner is better for FE - as long as the car doesn't have leaky seals or bad rings. In that case a thicker oil usually seals piston pressure better and will leak less also.
So far I've been determined to use only the weights recommended in my car's owner's manual for my climate. I don't dare go to x-20 because the book offers 15-40 and 10-30. 10-30 is it for me, at least for now.
Looks like the price you entered for a litre of gas is unrealistic. winstona Fuelly Web Support and Community News 6 05-12-2013 11:26 AM
Need help - my trip odometer was reset Keen4Green Fuelly Web Support and Community News 7 09-27-2010 07:27 AM
Someone Has Built An Efie ? SIFLIGINIUS General Fuel Topics 24 02-23-2007 03:28 PM
Gaslog suggestion SVOboy General Discussion (Off-Topic) 1 04-29-2006 09:35 AM
