Originally Posted by holypaulie
If you remove intake resonator you will lose low-end torque. Another words your car will lose power in low RPMs. I've done it and that's what happend to me.
yea i kinda felt that.
Originally Posted by dosco
Not sure exactly what you mean by "resonator."
Most modern cars have an intake "resonator" that looks like tubes folded over themselves. In some cars they're metal, I think in newer ones they're plastic.
They function to increase the intake charge pressure by acoustic resonance ... in the 4 cylinder cars I've owned, they kick in at 2,500 RPM or so, and their peak function corresponds with the peak torque.
I wouldn't recommend that you remove it. You're probably better off changing your driving technique.
exactly that. its the tube/box that goes from the intake filter to the wheel well and into the engine bay. i guess its kind of like a wai in a way. i am going to try and be a little more conservative with my driving with the intake resonator off to see what i can get from it. if i like it it will stay off if not then i will definitely put it back on.
