Installing smaller injectors to reduce consumption. - Fuelly Forums
Old 05-13-2008, 02:11 PM   #1
Anybody ever tried to use injectors that have less flow to get better mpg's ?
jfman is offline   Reply With Quote
Old 05-13-2008, 02:55 PM   #2
kamesama980's Avatar
either A. it'll run lean, the O2 will compensate, and no change. or B it'll run leaner than the O2 can compensate for which could damage the engine. like running a turbo without adding bigger injectors.
-Russell
Old 05-13-2008, 02:58 PM   #3
I was told that a lot of cars run slightly rich from the factory. WOuldnt this help.?
Old 05-13-2008, 03:30 PM   #4
EH3
EH3's Avatar
you were told mostly wrong
most cars are tuned on the rich side at WOT
EH3 is offline   Reply With Quote
Old 05-13-2008, 03:34 PM   #5
The way to do it is run smaller injectors preferably with a more efficient design (4 pintle or something) at higher pressure. Then you get better atomisation, for the same fuel, this may translate to better burn and the ECU will actually lean them back a little.
CNG and lack of Kg/cubic meter GeneraleRusso Fuelly Web Support and Community News 2 12-28-2010 10:13 PM
A New Tool for MPG Testing Bill in Houston Experiments, Modifications and DIY 7 06-12-2007 06:32 PM
