Innovate LC-1 WB O2 sensor Installed - Page 2 - Fuelly Forums
Old 04-15-2007, 04:02 PM   #11
Does the Megasquirt come with "default" maps for running any engine? Or are there G10 NA maps already done that approximate the OEM computer?
Old 04-15-2007, 04:24 PM   #12
CoyoteX's Avatar
it has some generic base maps and you can even generate a map based on the engine parameters that will get you in the ballpark. It is hard to tune an engine with a narrowband sensor since it only shows 14.5:1 and really nothing else. You can tune the entire map to 14.5:1 then extrapolate to the target AFR and be pretty close. That would save the expense of getting the LC-1 sensor. I plan on messing with the engine a lot so I went ahead and got a LC-1 for it. I can also use it to tune my other cars when I need to.
The MS can tune itself so you don't really have to manually tune it. Just get it close enough to run then drive around for a while and let it figure it out. Then normally they say go back and smooth out the map to make the engine smoother but I probably won't since I am not going for smooth I am going for mileage.
The MS setup I have is a pretty nice design. Once I get the bugs worked out and get it running with a decent base map then pretty much anyone could install one just by unplugging the stock computer and sticking this one in it's place. No rewiring required.
Old 04-15-2007, 04:26 PM   #13
Very excellent. You're probably a G10 XFi MS pioneer.
Odometer help/suggestion waterboysh Fuelly Web Support and Community News 10 12-14-2012 03:38 PM
Conversion successful Matt Timion Fuelly Web Support and Community News 12 05-18-2006 02:24 PM
Electric panel heaters GasSavers_JustMe General Discussion (Off-Topic) 0 01-03-2006 03:43 PM
