Injector kill automaticly for MT - Fuelly Forums
Old 03-03-2007, 05:25 AM   #1
caprice's Avatar
I was reading about engine off coasting, and engine off idling. The problem is remembering to do it all the time, and accedently locking the steering wheel while going down the road. What if, with "fuel pump" relays, you have it kill injectors while the BRAKE is PRESSED, but the CLUTCH is NOT? If it is in nuetral, you would be engine-off coasting. Then when the clutch is pressed (to put it back in gear) have another relay enguage the starter, and when there is engine vacuum (or something else that says the engine is firing), it disenguages the starter, because the engine is running, just in time to accelerate again.
Just an idea I had. Could also do an ignition kill at the same time, to save some power draw.
David
85 Chevrolet. 30 MPG or bust!
caprice is offline   Reply With Quote
Old 03-03-2007, 05:39 AM   #2
skewbe's Avatar
I've considered similiar combinations of using existing inputs to kill the engine, like if the car is charging and the clutch is put all the way to the floor then kill the engine (my clutch interlock switch is much more travel than needed for shifting), alas I went with a kill switch.
Turns out that an actual kill switch in an easily to use location has proven quite useful, in the cold my throttle cable FROZE OPEN and my engine started racing IN TRAFFIC. No problem, I just pulsed the kill switch with my finger to approximate something less than full throttle where needed till i got to the gas station and could get under the hood and work the throttle loose.
(spring loaded closed isn't ALWAYS fail safe)
No worries about locking the steering column and it just becomes a natural part of your driving if it is located conveniently.
here's the details of my kill switch:
http://www.gassavers.org/showpost.ph...1&postcount=30
http://www.gassavers.org/showpost.ph...0&postcount=34
Standard Disclaimer
Old 03-03-2007, 07:59 AM   #3
Tuggin at the surly bonds
Silveredwings's Avatar
Originally Posted by skewbe View Post
How is the microswitch holding up?
Old 03-03-2007, 08:07 AM   #4
skewbe's Avatar
no problems to report, knock on wood
Standard Disclaimer
Old 03-03-2007, 08:26 AM   #5
FE nut
diamondlarry's Avatar
I need to add a momentary contact switch to my injector kill system. Right now, I have a paddle switch. The problem is that you can forget to switch it back on. Not that would know...
2007 Prius,
Team Slow Burn
