rgathright suggested I put this in a thread for the rest of you.
I recently installed an alternator cut-off switch in my 1987 Civic. With alternator off it misfired a lot even with a 60,000volt coil.
Some setups expect that ~14volts coming from the alternator.
rgathright, setup a power supply in his Jeep so that it was always getting 14.1Volts. I messaged him, and he's come up with an even better idea. Two options actually.
You can run a 16Volt racing battery. Pretty simple install and everything. However, this prevents a charging problem as your 14volt alternator wouldn't charge the battery properly. There is possibly a solution.
http://thevbattery.com/cart/index.ph...roducts_id=270
It will boost your alternator from 14Volts to 16Volts so you can charge your racing battery. It will also boost your 12Volt battery to 16Volts, from what I understand on the page.
rgathright has emailed the distributor of them to confirm that it will work for the application.
Originally Posted by rgathright
FIRST, make this a thread, people in the forums could use this information!
Second, they have onboard DC-DC converters in race cars that do this for you. I used them during my circle tracking racing days to recharge cars in the pits. I emailed the distributor at the website link below and hope to have an answer for you soon. http://thevbattery.com/cart/index.ph...roducts_id=270
Hope this all works, several car owners out there will enjoy reading your discussion on the conversion!
