03-01-2007, 05:58 AM
Originally Posted by ELF
My car will not run with the wire disconected, It will run if I keep pushing on the throttle but soon as I let up the engine dies.
If it's a motor and not a solenoid you need to disconnet with the engine running at the idle speed you want it to be at. If you disconnet with the engine off you'll get those results.
03-01-2007, 06:41 AM
skewbe-
Originally Posted by skewbe
typo, impirical evidence and physical examinations shared here all point to it being a motor, and a rather goofy one at that.
I think we're both right. This is from the "Identifying Wiring Diagram Symbols" table in my electronic Saturn manual :
This is a picture of what the idle control valve is from an electrical standpoint :
What the image above implies to me is two solenoids controlling a motor. The blue wires control the "A" solenoid and the green wires control the "B" solenoid.
Hypothesis : If we knew the amount of volts/amps to send thru the green or blue wires at any one time, we could take FULL independent control of the Saturn idle air control valve  .
Does this make sense  ?
03-01-2007, 09:44 AM
Quick Quiz
Is this (assuming it works and is turning) a solenoid or a motor?
P.S. Yes, it is quite possible to put a manual control on the idle speeed motor, look at what voltages the computer is sending on what wires for a starting point.
03-01-2007, 09:56 AM
I would call that a solenoid. It just has a linear to rotary converter on the end, but a solenoid at heart.
That looks like a step motor symbol to me. A 2 phase stepper to be exact, thats why there are two winding sets with iron bars in the symbol. A step motor is well suited to that kind of positioning job. Kind of like the ones in computer printers.
03-01-2007, 10:01 AM
jwxr7 -
That looks like a step motor symbol to me. A 2 phase stepper to be exact, thats why there are two winding sets with iron bars in the symbol. Kind of like the ones in computer printers.
So it probably is a stepper motor after all. That makes sense to me, since it "sits in place" when the juice is off. Other people said it needs more than 4 (5?) wires to be a stepper motor.
03-01-2007, 10:07 AM
Not necessarily, most of the ones I deal with only have four wires because they are two phase . there are some with three or more phases, which would require more wires  .
skewbe -
Quick Quiz
Where does the hamster fit in? How can it turn without a hamster spinning the wheel? Is the wheel the multiple ovals above the "-" sign?
03-01-2007, 12:10 PM
I would call that a solenoid. It just has a linear to rotary converter on the end, but a solenoid at heart....
ok then, what is this device, motor or solenoid?
03-01-2007, 12:18 PM
#19
FE nut
I'll probably post this somewhere else but, I just picked up a complete set of Saturn factory service manuals. I'll see what they call the Saturn part in there.
2007 Prius,
Team Slow Burn
03-01-2007, 02:16 PM
#20
FE nut
Below is a quote from the service manual:
The PCM controls a two-coil stepper motor which controls the bypass air intake into the throttle body to decrease or increase engine idle speed.
2007 Prius,
Team Slow Burn
