IAT Sensor Mod (Resistor Mod) - Fuelly Forums
Old 10-16-2005, 09:17 AM   #1
FE nut
diamondlarry's Avatar
Okay, now I think I
Okay, now I think I understand what you're asking. It sometimes takes us old guys awhile to catch on. :-) You would have to know in advance what the load(Amperage) of the device is that you're going to power. Then it would be a matter of coming up with the resistor values. A simple way to do 12 down to 6 volts would be to use two resistors of equal value in seies. Then you would tap the junction netween the two resistors and place your item between there and ground. As I said above, you need to know the current draw because if you use to high a value of resistors you won't have enough current available; too low and things get hot.
Larry
2007 Prius,
Team Slow Burn
Best ever tank notification - 1st time only? bedbug Fuelly Web Support and Community News 6 05-23-2010 01:51 AM
No EPA Est for 2007 Chrysler Town & Country jklaiber Fuelly Web Support and Community News 1 08-23-2008 12:15 AM
Matt you'll find this interesting. Compaq888 General Fuel Topics 25 01-11-2006 02:08 PM
