IAT Sensor Mod (Resistor Mod) - Fuelly Forums
Old 10-05-2005, 04:14 PM   #1
I was going to try out larry's IAT mod on my friends saturn tomorrow, I even had two 220 ohm resistors hooked up in parallel to do it:
But he wussed out last minute. So I have a few questions.
Has anyone besides larry done this?
To larry: I know you said the heat isn't different, but are you worried about running too lean or oxidation or anything? How many miles have you been running this set up? I know you have EFIE, but with this can you figure out your AFR? That's all I can really think of now, but mehbe I'll ask some more later. I'd love to try this, just wanna mehbe get some answers to convince this guy since I'm in the middle of my acetone test.
EDIT: If anyone wants a set of resistors in series that add up to 110ohms (like the ones on the bottom) I have tons of resistors around and I'd be willing to send some out to you so you don't have to buy a bunch of crap or locate a bunch of crap. That way we can also get you on testing a bit faster. Also, if you're non obd0/1 honda, I could prolly figure out what resistance to use, but it'd take me some time if possible.
Old 10-05-2005, 05:56 PM   #2
FE nut
diamondlarry's Avatar
I have been running this mod
I have been running this mod since April. Up until 3 weeks ago, I drove 200 miles/week just for work. With all of the other running around, it probably ended up being 300-350 miles or more a week. At 300 miles a week this figures out to around 6,000 miles. Back when I did my sparkplug testing, I had my plugs out fairly regularly and never noticed any signs of running severely lean. As far as AFR goes, I don't have any way to check that.
2007 Prius,
Team Slow Burn
Old 10-05-2005, 06:29 PM   #3
Thanks
Yeah, I'll show this to him and try to sway him, but I might just wait for my own testing to be done for it.
Old 10-06-2005, 02:19 PM   #4
Testing
What's the best way to figure out the resistance I need for my stuff? Should I boil some water and dip the sensor in there and measure the resistance with a multimeter?
Old 10-06-2005, 02:47 PM   #5
FE nut
That should work.
That should work.
2007 Prius,
Team Slow Burn
Old 10-06-2005, 02:56 PM   #6
Mmkay
I don't have a multimeter handy, so I'll do it tomorrow hopefully and post up the results. I'm still hoping on acetone, but it seems like every time I start the car the needle drops randomly and won't go back up to where I started it from so it worries me, haha.
Old 10-07-2005, 01:12 PM   #7
Honda IAT stuff
So, it's 74 degrees out now and my multimeter just read 61.5 ohms of resistance across the IAT sensor. So I'm wondering if the relationship is linear or what, cuz if it was I could just heat it up a bit and test it and then make a line to figure it out, but I think it'll be above 110 ohms.
Old 10-07-2005, 02:03 PM   #8
Honda Numbers
Okay, forget what I measured just now, cuz it's no good. Here's the real numbers for the 88-91 Honda D15B2:
100 ohms = 248 degrees
20,000 ohms = -40 degrees
Seems that all obd0 and obd1 stuff uses the same values, so that should be good for all the honda stuff at least, I dunno about obd stuff outside of honda.
I'll see if I can get a b18c1 thing for flatland...
Old 10-07-2005, 04:16 PM   #9
This is a picture of my IAT for Matt. This on a 91 crx dx with a d15b2 and dpfi.
Old 10-14-2005, 01:38 PM   #10
just a quick resistor ?im
im not so good with electronics, but if i wanted a 12v power wire in my car to be reduced to say 3v or 6v or 9v, how would i do that?
dfoxengr is offline   Reply With Quote
Best ever tank notification - 1st time only? bedbug Fuelly Web Support and Community News 6 05-23-2010 01:51 AM
No EPA Est for 2007 Chrysler Town & Country jklaiber Fuelly Web Support and Community News 1 08-23-2008 12:15 AM
Matt you'll find this interesting. Compaq888 General Fuel Topics 25 01-11-2006 02:08 PM
