i want to get 35MPG out of my pick up truck - Fuelly Forums
Old 11-12-2009, 08:42 PM   #1
i have a 2002 2wd reg cab toyota tacoma 2.4 4 cylinder 5 speed pick up and i would like to get 35mpg. the stock epa was i believe 26 mpg highway. i have the tires inflated to 44 psi and i have the grill blocked off 90% . i also have a drop in k&n air filter on the truck and driving at 65mph with the tailgate down i am just cracking above 30 mpg (on a gps not the speedo) of straight highway driving. i would like to know what people think i should do to get my mpg up. i am not looking to spend lots of money to get 5 more miles per gallon. also the truck has 200,000 miles on it and it isnt the nicest truck and i would have no problem with modifying it.
i am thinking about an areo cap on the back from the back of the cab to the bottom of the bed with the tail gate removed so it makes the back more of a point. any thoughts on how many mpg i would see out of that? i dont really want to put a whole bunch of funny looking areo stuff on the truck if it is only going to give me 1 more mpg.
i am also thinking about a hot air intake.
how about taking off my ac belt for the winter? anyone have any experience with that?
i tried taking off my fan on the motor but the motor started creeping up in temp so i put it back on. an electric fan? anyone have any experience with that?
GasSavers_ccrider is offline   Reply With Quote
Old 11-12-2009, 09:07 PM   #2
Arrow
THere's a lot you can do depending on how detailed you want to get, but generally its a myth that trucks get better mileage with the tailgate down. Try some runs with the tailgate up, that should take you one step closer to your goal. For more ideas look at "The Beast" in my garage.
Old 11-13-2009, 07:51 AM   #3
Jay's right about the tailgate.
Your ideas are good.
Aero cap: Read up on it, I think you want an 11? slope.
HAI: Go for it.
A/C belt: Your truck probably has a single serpentine belt. You could replace the whole thing with a shorter one that skips the A/C, but I'd just rig it to not run the A/C when running the defroster.
Electric fan: Common mod on GM full size trucks, but usually the people doing it aren't tracking MPG and are looking for horsepower. For the GM full size I think people are doing it with junkyard Ford Taurus electric fans.
Old 11-13-2009, 07:52 AM   #4
More thoughts: Usually, the best MPG mod you can make, and one of the only cost-effective ones, is to adjust your driving. What have you done to your driving style?
Old 11-13-2009, 02:04 PM   #5
on my truck the ac belt just goes around the harmonic balancer and the ac compressor.
i would feel better putting a ford taurus electric fan on my truck instead of a cheap auto part store fan that is made in china.
i was just driving real light on the gas and trying not to use the brakes. the time i got over 30 mpg i was on a long trip and filled up. got on the highway and ran the tank out
so you think i should build the areo cap with the taligate off or on? any ideas on the areo cap mpg? 1 mpg or 4 mpg? i have no idea just wondering if anyone has info.
Old 11-13-2009, 02:15 PM   #6
Definately do it tailgate up. You are looking for no more than an 11 degree slope going down from the roof. Once the air is already flowing that way it will continue in that direction beyond the tailgate, kind of like a kamback. The whole notion that tailgate down is better was put in our minds by companies trying to sell us tailgate nets.
Old 11-13-2009, 02:43 PM   #7
if i make the aeor cap with the tailgate up isnt there the same flat spot as behind the cab just a little smaller behind the tailgate? wouldnt it be better given the angle from the roof to the end of the bed is less than 11 degrees with the tailgate removed?
Old 11-13-2009, 02:58 PM   #8
No, because of the 11 degree angled slope. The air will continue to slope and taper beyond the tailgate, as if the vehicle had the slope continue beyond the tailgate.
Old 11-13-2009, 03:15 PM   #9
The flat spot behind the tailgate is there whether or not there's the flat spot behind the cab, so at least improving the one behind the cab is better than nothing at all. If you really wanted to, you could extend the cap past the rear of the vehicle.
You could also install a belly pan.
For driving style, you can do a whole lot of different things. Your manual transmission enables you to use even more techniques than an automatic would allow -- namely, you get real control of what gear you're in without gear choice being related to throttle usage, and you get to try engine-off coasting (advanced technique that I wouldn't recommend trying immediately, or ever depending on various factors).
I would recommend experimenting with shifting at different RPM and with using the throttle differently. In my manual transmission car, I am never light on the gas, and I'm 74.8% above the EPA rating. However, that doesn't mean that I go particularly fast. I shift very low, entering my next gear at almost idle, and I floor the gas pedal every time. Most vehicles can't use those extremes; you might need to enter your next gear at 1500rpm and use 75% of the gas pedal. Granted, that won't help you on the highway.
You might also experiment with coasting (engine-on) and Pulse & Glide.
Old 11-14-2009, 12:22 AM   #10
imzjustplayin's Avatar
For the tailgate thing, check out the myth buster's episode..
Partial fuel-up - when do you reset your trip odometer? johnclayton Fuelly Web Support and Community News 2 07-30-2009 10:16 PM
drivetrain resistance bagpipe goatee General Fuel Topics 9 09-14-2008 10:04 PM
Feature Request: City vs Highway jethrographic Fuelly Web Support and Community News 1 08-08-2008 10:43 AM
New member - CA and 48 state computers jshelton441 General Maintenance and Repair 3 05-16-2008 07:20 PM
Experimental Engine Designs rh77 General Fuel Topics 8 08-30-2007 08:23 PM
