I think I'm ready for my Swap now - Page 2 - Fuelly Forums
Old 07-31-2008, 12:18 PM   #11
Member
78si's Avatar
Originally Posted by maxpowers View Post
So I have to remove the timing belt cover, remove the engine mount bracket, and bolt on the hf motor mount bracket in order to use the hf mount?
Yes
78si is offline   Reply With Quote
Old 07-31-2008, 02:11 PM   #12
Thanks 78si!!! I actually just got back from the junkyard with the hf mount but am having a hard time removing the timing belt cover.
GasSavers_maxpowers is offline   Reply With Quote
Old 07-31-2008, 02:21 PM   #13
Loserkidwac's Avatar
Send a message via AIM to Loserkidwac
The crank pulley needs to be removed to completely remove the plastic cover...you might be able to get away with just taking all the bolts out and trying to push it to the side but I think thats gonna be a pain...might as well swap in a new timing belt and water pump while the motor is out of the car too so you will have to remove it all anyways...I just swaped a D15z1 and trans into my Del Sol, a little easier than your swap but if you have any questions I've been messing with Hondas for a while now PM me...
MPG Noob
03 Mazdaspeed Protege
91 Honda CRX Si
95 Honda Civic VX *RIP 5/20/08
94 Honda Del Slow D15z1 Swapped
Loserkidwac is offline   Reply With Quote
Old 07-31-2008, 08:27 PM   #14
Yipeeee!!! I just dropped the motor on. Kind of. I managed to only have it on by 1 motor mount which is the drivers side. Still waiting for my transmission to come in from canandaiaaaaa. From the looks of it, I think the other 3 mounts bolt onto the transmission. I did manage to remove the engine mount by bending the plastic cover while managing to not break it. I know it's going to be a pain dropping the transmission in once I receive it, or maybe I can just bolt it on from the bottom of the car. Only time will tell.
Old 07-31-2008, 11:17 PM   #15
Member
78si's Avatar
Where did you finda HF tranny?
Old 08-01-2008, 11:16 AM   #16
JDM Source...They quoted me at 300 with shipping. Don't know if that's too much or not. Does anyone have any pics of a 88-91 crx with the d15z1 in it. I'm trying to figure out how the intake box goes.
Old 08-01-2008, 02:52 PM   #17
Member
78si's Avatar
I install engines for JDM Source.. I doubt your getting a HF tranny. Your probably getting a complete VX swap, which has the hydro tranny. You need a HF cable tranny.
Old 08-01-2008, 02:58 PM   #18
Member
78si's Avatar
Here is a VX engine in a 89 civic (same engine bay as the CRX)
Old 08-01-2008, 07:55 PM   #19
friz's Avatar
78si you seem to be very knowledgable on this swap. How much would it cost me to do this swap in my 89 HF when the motor goes? If anything I would like it for the reliability of OBD1. I do have a few swaps under my belt mostly JDM B series into EG's. Please excuse the hijack at least it's on the same topic.
I used to curse when I got stuck behind you guys on a two lane blacktop. If you can't beat em?
friz is offline   Reply With Quote
Old 08-01-2008, 09:35 PM   #20
From what they told me at JDM Source, it was from the crx cx which is the same as the crx hf in the US. I actually bought the vx engine complete with the harness, axles, and everything else that was inside the engine bay from craigslist with the transmission. I removed the transmission prior to dropping the engine and am just waiting for the hf (or cx) transmission to come in.
Small issue with fuel entry, leading zero metalfan49 Fuelly Web Support and Community News 1 08-07-2013 08:08 AM
Incredible Jetta Diesel halfish Introduce Yourself - New member Welcome 7 06-02-2007 06:15 PM
Hey people: enter your location in your profile please MetroMPG Fuelly Web Support and Community News 7 02-18-2007 08:58 AM
What are your shifting patterns??? Compaq888 Hypermiling 13 08-22-2006 07:41 PM
A radiator door for the grill block basjoos General Fuel Topics 26 04-20-2006 07:51 AM
