I just bought an 05 Neon - Fuelly Forums
Old 04-20-2008, 11:38 PM   #1
Send a message via AIM to anon9 Send a message via MSN to anon9
Recommend me some things I can do to help improve gas mileage.
Anything from $0-$500 MAX. Anything is appreciated.
anon9 is offline   Reply With Quote
Old 04-21-2008, 05:13 AM   #2
Slothman86's Avatar
Don't speed!
Slothman86 is offline   Reply With Quote
Old 04-21-2008, 06:53 AM   #3
GasSavers_BEEF's Avatar
welcome, good to see another carolina guy on here. one thing is a scangauge. this will tell you what your mpg's are in real time and also give you a trip mpg meter as well. this will tell you when you are really sucking the juice. also after you get the scan gauge (retalis for $170 or so) you can look into a grill block. this is where you block off part of your grill to increase aerodynamics and allow your engine to heat up faster. it is good to do this after you have the scangauge because you can monitor your coolant temps.
other things people are doing include: increasing tire pressure to tire wall max, adding makeshift skirts for the rear tires, adding belly pans, removing side view mirrors, poping it into neutral going down hills, cutting off the car going down hills, adding elaborate boat tails for aerodynamics.
the first and foremost thing (which is free) is driving style. keep your rpms low and your car in the highest gear and that will do wonders.
I am sure there are more things but I would (and did) start with the scangauge
*edit* disclaimer: some of the stuff may be borderline legal (ex. side mirrors) so check your local laws about what is and isn't legal before doing things that are way out there
Gear, Engine, and MTF Oils 95metro Automotive News, Articles and Products 24 04-29-2010 04:56 AM
WTB: CX/VX civic 5 spd tranny. first350 Wanted to Buy 13 03-09-2008 12:04 AM
requesting a water pump experiment bzipitidoo Experiments, Modifications and DIY 12 08-17-2007 08:48 PM
Cruise Control in Civic McPatrick General Maintenance and Repair 16 07-13-2007 04:20 PM
Drafting 18-wheelers....revisited Brian D. Hypermiling 26 05-22-2007 02:51 PM
