Hydrogen Generator! - Page 8 - Fuelly Forums
Old 11-14-2005, 01:32 PM   #71
Wow! That's a heck of a lot,
Wow! That's a heck of a lot, another good reason to keep this thread running, :-)
Old 11-14-2005, 02:39 PM   #72
Compaq888's Avatar
Well as I said my cousin
Well as I said my cousin told me that pure gold and silver almost/don't corrode. He knows what I'm talking about. He can even write out the whole formula, I can't.
Old 11-14-2005, 03:15 PM   #73
FE nut
diamondlarry's Avatar
I just got an email from
I just got an email from Fran and he said it would cost $80 for the plans and you would have to sign a liscensing agreement. Here is a quote from Fran's site about his generator.
"What is the Hydrogen-Boost System?
The Hydrogen-Boost System is a gas mileage enhancement system based on the main component, an on-board hydrogen gas generator. We build the most efficient and maintenance free, affordable, compact hydrogen gas generators in the world. Tests have shown over 95% efficiency on some of our prototypes. Our typical hydrogen generator will produce 1.5 to 2 liters of alternative fuel gas (hydrogen and oxygen mixed) per minute using twelve volts and 20-30 amperes."
2007 Prius,
Team Slow Burn
Old 11-14-2005, 04:46 PM   #74
Ah damn, 80s too rich for my
Ah damn, 80s too rich for my blood right now, :-(!
Old 11-14-2005, 05:18 PM   #75
FE nut
I know how you feel. With
I know how you feel. With some medical things that are going on with my wife, $8 might even be a little rough at the moment. ;-)
2007 Prius,
Team Slow Burn
Old 11-14-2005, 10:19 PM   #76
Compaq888's Avatar
We will work something out.
We will work something out. I'm still working on mine. I'll give you all the part numbers and links where to buy it. Before I can even start to assemble it I have to test out the electrodes.
Old 11-16-2005, 12:00 PM   #77
Producing O2 might actually
Producing O2 might actually be a good thing. You'll get better combustion because of more O2 in the cylinder. It'd be like an electrochemical turbo. But then if more O2 in the cylinder actually uses up more gas (do turbos and superchargers increase fuel economy? that's debatable) you might be better off not using the O2. The gasses can be kept separate with a little more work. I was even thinking about putting H2 into the PVC valve vacuum line and the O2 into a barb that's already installed on my intake tube. I don't know if it'd be best to leave the O2 out of it, though.
Gold and silver electrodes are good but very expensive. You'd have to make sure they have an infinite lifespan or replacing them is going to cost a lot. I've heard that platinum is acutally a better electrode. Even more costly though.
Electrolysis is definitely the way to go for producing H2. It's relatively easy and once the corrosion problem is solved, it won't consume any materials (except for a little electrolyte at a VERY slow rate). Plus it can be turned off with the flick of a switch.
Flatland2D is offline   Reply With Quote
Old 11-16-2005, 12:21 PM   #78
Moderator
GasSavers_DaX's Avatar
Re: Producing O2 might actually
..as long as you add more fuel to the mixture.
Old 11-16-2005, 02:42 PM   #79
Compaq888's Avatar
Yeah we don't want more
Yeah we don't want more oxygen in there. Because if we get more oxygen our fuel intake will go up and defeat the purpose of putting a hydrogen generator.
So the next question is how can I separate oxygen and hydrogen when it comes out the chamber?
Old 11-16-2005, 02:52 PM   #80
FE nut
If you get an EFIE from
If you get an EFIE from George Wiseman the ECU won't "see" the extra O2 and the fuel consumption won't go up.
2007 Prius,
Team Slow Burn
Can't change vehicle pic?! lauriejennifer Fuelly Web Support and Community News 2 04-29-2010 12:05 AM
API for fuel ups busbeytheelder Fuelly Web Support and Community News 1 03-28-2009 01:21 PM
Road and Track story on saving Fuel VWJunky General Fuel Topics 3 11-20-2008 03:44 AM
Simple math johnyaya Fuelly Web Support and Community News 1 10-27-2008 01:31 PM
The Mechanic was like, "WTF?" rh77 General Fuel Topics 15 02-14-2006 04:15 PM
