How to make the intake air more humid to save gas. - Page 5 - Fuelly Forums
Old 01-03-2006, 05:07 PM   #41
Windshield washer pumps
Windshield washer pumps probably don't last too long.
Capcom is offline   Reply With Quote
Old 01-03-2006, 05:22 PM   #42
FE nut
diamondlarry's Avatar
Actually, a small inverter and a fish aquarium pump might last longer. The problem is that it may not put out enough volume.
2007 Prius,
Team Slow Burn
Old 05-31-2006, 06:54 PM   #43
GasSavers_maxc's Avatar
water injection
A lot of water injection systems flow to much. All you need is 1 to 3ml per min with a 2.0 liter engine at low engine speeds. Thats a .001 orifise or less at 10 to 17 inch of manifold vacuum pull. Or no.28 needle at medical supply store.
less lurking and more working
Old 05-31-2006, 07:29 PM   #44
Originally Posted by SVOboy
I know this, I was thinking right before the butterfly. I might just set it up with a windshield washer pump and a fuel injector, then set it up with some sort of variable load valve that works off of a pressure sensor coming off the MAP line. I dunno though.
Search on the internet someone already tried the injector trick and it will corrode and not open.
mikefxu is offline   Reply With Quote
Old 05-31-2006, 07:34 PM   #45
I've heard injectors are too big anyway, since I posted that more than half a year ago or whatev, , my learning curve is embarassing.
Old 05-31-2006, 08:07 PM   #46
Opps didn't see how old post was.
Old 06-01-2006, 07:09 PM   #47
basjoos's Avatar
High humidity improves mileage for two reasons. The water molecule (atomic weight 18) is much lighter than nitrogen (28), oxygen (32) or carbon dioxide (44) molecules, so if there is lots of moisture in the atmosphere, it reduces the density of the air your car is plowing through. Also water molecules in the air displace some of the oxygen molecules that your engine would normally be combusting. So high humidity has the effect of reducing the amount of oxygen that your ICE can suck in, which also reduces the amount of gasoline burned and the amount of power produced by the ICE.
They used water injection in some supercharged WWII aircraft, but there is was mainly used under steady state (fixed throttle) conditions with about 80% to 90% throttle. Aircraft engines are operated very differently from the average car ICE, since aircraft engines are run closer the full power most of the time and the RPM's remain more constant. Unlike car ICE's that are run at low power settings most of the time and the RPM's are often rapidly changing.
A method to set up a constant high humidity entering the intake manifold may help to improve mileage, but a water injection (spraying jets of water into the intake) wouldn't. The peizo room humidifier may work provided it can produce enough mist to keep up with the ICE's air intake demands and if the electricity required to operate the peizo doesn't eat up your energy savings via heavier demands on your alternator. The peizo will also need to adjust its output to your ICE's air demands, otherwise if you spend some time idling in traffic with the peizo running full tilt, you may end up killing the engine with excess water.
aerocivic.com
Old 06-01-2006, 09:35 PM   #48
Every small block Chevy I've ever owned has ALWAYS run better in the wet damp weather!
Kevin A Thornton
KAT Automotive
For Speed Equipment, Nitrous Express
katman@everestkc.net
For AMSOIL products
https://www.lubedealer.com/kat
For Herbs from the Amazon
https://www.168336.amazonherb.net
GasSavers_katman is offline   Reply With Quote
Old 06-08-2006, 04:59 AM   #49
I talked to my automotive engineer friend, and come to find out that the O2 sensor is going to see the additional oxygen from the water vapor and add more fuel to match it. The Mother Earth stuff was before the days of O2 sensors. With an EFIE and wideband O2 sensor it might be doable, he said.
cheapybob is offline   Reply With Quote
Old 06-08-2006, 05:06 PM   #50
So what your friend is saying is water is being split into hydrogen and oxygen. The hydorgen is being burnt and there is oxygen still left over or there is no spitting and just air in the water is released?
Best Diesel in N. Texas? JudisJetta General Fuel Topics 7 05-28-2010 09:55 AM
