**how Old Are Your Tires?!!** Please Watch!! - Page 4 - Fuelly Forums
Old 07-24-2008, 05:56 AM   #31
Originally Posted by Ven View Post
I appologize for going off. Hope I didn't make too much of an *** of myself.
It happens. I've done the same before, too. I know you've felt like I'm picking on you a couple times, but it's just because I don't always communicate as pleasantly as possible.
Old 07-24-2008, 11:38 AM   #32
My tires are code 113, March 1993. The car was built in September.
Still has the original wheel weights and rides perfectly.
If I feel any vibration, it is corrected immediately.
None in 7500 miles.
I'll replace them when they are worn out, probably within the next year.
The same goes for the fan belts, and the timing belt.
I will probably do the timing belt and fan belts at 45k when the tires are worn enough to justify replacement.
My car is a unique situation, and I wouldn't dream or recommending the same thing to anyone.
Stored inside in a controlled environment makes all the difference in how a vehicle ages.
Most tire failures are due to underinflation.
regards
gary
Old 07-25-2008, 03:27 PM   #33
My '97 Escort has less than 25,000 miles on it and still has the original tires on it and has been driven approximately 2500 miles in the past month and a half. The car is garage kept so it doesn't get the direct sun light though. The tires still show no signs of cracking or dry rot.
Hipermiler
#47 on my way to #1
Old 07-27-2008, 11:56 AM   #34
imzjustplayin's Avatar
Originally Posted by thisisntjared View Post
i drop the rear pressure a good amount so that the sidewall flexes enough to let the car to rotate when i throw it hard into tighter turns. but yea, when i chalk the front tires i end up having the pressure at the maximum anyway.
What? Um aren't you suppose to decrease traction at the rear and increase traction at the front in order to increase oversteering ability for a FF car?
Old 07-27-2008, 01:50 PM   #35
That's exactly what thisisntjared said he does, in the bit you quoted.
Old 07-27-2008, 02:57 PM   #36
|V3|2D
thisisntjared's Avatar
MPG not avaliable Fobulous Fuelly Web Support and Community News 2 09-06-2011 03:01 AM
MPG dropping - hot weather? Keen4Green General Fuel Topics 13 08-17-2010 08:57 AM
iPhone interface - I missed a fuel up check box is distorted funkd00bi3st Fuelly Web Support and Community News 2 08-13-2008 10:19 AM
Geo suspension Welding / Rebuilding JanGeo Experiments, Modifications and DIY 10 08-17-2006 05:03 PM
The Aerostar Gets Aero Mods 95metro Aerodynamics 19 06-22-2006 04:28 PM
