How much of an increase in mpg can I expect with overinflated tires? - Fuelly Forums
Old 10-11-2007, 04:31 PM   #30
DarbyWalters's Avatar
The difference is not readily discernable to the eye...use a pyrometer and take temps across the tread...you WILL see a difference. The higher temps in the middle show an overinflated tire and uneven wear will result. You just have to weight the cost savings verses the wear factor...you have to assume that the vehicle is properly aligned
Higher pressures are used in Auto-X to keep tire squibb to a minimum...you dont' have time to build up heat on a run
Lower pressures are used in Road Racing...heat builds and psi increases
For the street you are pretty safe unless you run underinflated...BOOM!!!
New Feature: Loan and lease cost labrie Fuelly Web Support and Community News 1 02-08-2012 01:12 AM
Ability to comment on Fuel Tips randomic Fuelly Web Support and Community News 4 08-21-2008 11:25 PM
