How much does weight have to do with fuel economy??? - Page 4 - Fuelly Forums
Old 06-09-2006, 07:22 AM   #31
krousdb's Avatar
Originally Posted by Sludgy
If you remove sprung weight, like seats, spare tires and the jack, the car will ride higher, making it less aerodynamic.
I removed my coilovers and went back to the standard springs and ride height because of the harsh ride. The ride height was raised 1.75". I have noticed no ill effects to FE at highway speeds.
Old 06-09-2006, 02:45 PM   #32
Compaq888's Avatar
seriously a 100 lbs won't raise the car when it weighs 3000 lbs. Now if you remove the 400+lb motor then it will raise.
Old 06-09-2006, 02:48 PM   #33
The front of my car is noticably higher after dropping ~50 pounds from the transmission swap. About a finger higher based on my finger measurements,
Old 06-09-2006, 02:51 PM   #34
Compaq888's Avatar
yeah but you now have a 2000 lb car, huge difference
Old 06-09-2006, 03:23 PM   #35
Yes, 3000 pounds is 50% more than 2000, and the weight that was previously talked about, 100 pounds, is 100% more than 50 pounds. So if you want to do the math you'll learn that the difference with the 100 pounds is greater than with my 50 pounds.
Old 06-09-2006, 04:54 PM   #36
kickflipjr's Avatar
When I remove everything in my trunk (around 45lbs) it affected the ride height in the rear.
Removing rearward weight will help some with drag race lanches.
2008 EPA adjusted:
Pulse and Glide? Pete7874 General Fuel Topics 24 02-26-2009 12:11 PM
