How much does alignment affect FE? - Fuelly Forums
Old 06-28-2008, 06:37 PM   #1
the answer is a TON!!!!!!!
I recently did an autocross alignment (lots of negative camber) my milage plummeted from 31.7 to 25.3 MPG . I will be going back to the stock settings as soon as I can. this hurts the pocket book real bad
Old 06-28-2008, 07:02 PM   #2
Did you reset the toe? I think it will usually go toe in when you add negative camber. I've got some negative in on mine but I've got the toe as neutral as I could and it rolls for miles and will still hook in hard.
Old 06-28-2008, 10:10 PM   #3
yep toe was set to stock specs but camber was set to -3*in the front and -2.5* in the back. I will be having the car re-aligned to the stock camber and toe settings .75* front and 0* rear camber before my new tires go on. I have seen these cars get 36mpg highway and I hope that I will see that soon.
Old 06-29-2008, 03:34 AM   #4
I can imagine increase RR from the tire riding on its corner all the time, squashing one sidewall badly, and having to bend the tread in a direction it isn't designed to bend very much.
Old 06-29-2008, 03:52 AM   #5
I got stopped by a cop once because I was driving a car to another shop with a bent frame. It was bent badly enough that the tires were squealing going straight down the road and if you took your hands off the wheel it would do a 90 degree turn in about 2 seconds.
Pulled the frame and drove back fine.
Dont know what the mileage was, I was too busy trying to keep it on the road, but I'll bet it was less than 1/3 of what it would have been with the wheels pointing in the right direction.
35 years ago.
regards
gary
Old 07-04-2008, 04:21 PM   #6
the alignment is back inside the factory specs and the LRR tires are on I also added some moon disk wheel covers. it will coast forever now.
Old 07-05-2008, 04:53 AM   #7
goofy1's Avatar
very nice looking moon disc on the Lord Vader. as the coasting long distances let me quote Vader "the force is strong with this one"
"But Doc, we dont' have enough road to get it up to 88 miles per hour"
goofy1 is offline   Reply With Quote
Old 07-05-2008, 09:02 AM   #8
"Never underestimate the power of the force"
preliminary results revealed 36 mpg. Hard data will follow on friday after a week of commuting.
anyway on to the better pics.
Water Carburator GasSavers_Scott Experiments, Modifications and DIY 27 01-20-2008 01:56 PM
Aerodynamic Mirrors (fluid dynamics help?) edenstrang Aerodynamics 25 12-22-2007 03:42 PM
Fuel cut-off threshold speeds GasSavers_Rotareneg General Maintenance and Repair 10 08-13-2007 05:27 AM
FFI GasSavers_MPGmaker Introduce Yourself - New member Welcome 39 05-30-2006 03:31 PM
Will from Michigan n0rt0npr0 Introduce Yourself - New member Welcome 4 11-03-2005 01:47 PM
