how i did it (Fuel heater) - Page 9 - Fuelly Forums
Old 06-22-2008, 07:36 PM   #81
GasSavers_maxc's Avatar
Everyone would freak out if they saw my fuel heater. If I drive for 4 hours at 40mph the fuel in the tank is 20F higher than out side temps. Witch Is'nt that bad. I thought it would be higher. The exhaust is running 30% cooler now. With HHO too.
less lurking and more working
Old 06-22-2008, 07:46 PM   #82
Tepco's Avatar
Originally Posted by R.I.D.E. View Post
I was a certified Master Tech in 1978, now I am a tired semi disabled old man, who has two patents pending on designs for vehicle powertrains that I know can make a huge difference in this world and could change the global climate after I am dead and gone.
Cant wait to see what it is, don't let the oil companies buy it out...
Gas?? Oh you mean the expensive smelly stuff Grandpa used to power his car with? Silly old Man.
Get off my @ss I'm saving gas!!
Tepco is offline   Reply With Quote
Old 06-22-2008, 07:46 PM   #83
This thread is dumb as hell. Ya don't even have to go past the second sentence in the first post to see that.
The beer coozie would be better utilized by putting a nice cold beer in it.
Your right. LOL
Old 06-22-2008, 08:04 PM   #84
ok great dont do it....ive seen in run on vehicles for years with no problems and constant mpg....my setup uses armorflex, the guys that made and installed the first one used abeer coozie which worked fine...like i said before it works for me and everyone that had one installed
chope is offline   Reply With Quote
Old 06-22-2008, 09:04 PM   #85
Originally Posted by RoadWarrior View Post
However, on many engines the fuel rail is nice and cozy against the head, often shielded by intake parts or valve covers, and it soaks near to coolant temperature anyway... but that happens after the FPR and tank return... so I'd say there's probably no risk to the injectors, o-rings etc at that end, because they should be designed to cope with heat soak from the head.
Heat soak will get the temps up for a short time but during normal use the fuel flow with the gas tank acting as a radiator keeps the temps down everywhere the fuel goes. The hot intake valve is the first time the fuel sees heat that it can't beat. In the winter it is easiest to observe. Feel the temp in the notch between the injector coil body and the engine which is the very last part the fuel flows through before dropping into the intake. The coil body will be hot but the fuel part will be stone cold which means the fuel leading up to it is just as cold.
On my GM 3.8L rail the upper o-ring is black (n-buna) and the lower o-ring is bi-color brown/black (viton/n-buna). The black (n-buna) part faces the little bit of cold fuel back spray and vapor and the brown (Viton) part holds the seal in the hot intake bore. Neither color can last under the conditions the other sees. GM's top ring is all black which sees continuous liquid fuel but little heat. After 240,000 miles these bi-color o-rings functioned like new. I have rebuilt rails and the rebuilder knowing nothing about o-ring chemistry put all black o-rings on. Within 70,000 miles the bottom rings split during removal and were flattened to where they wouldn't hold a seal. The upper o-rings are like new. I bought 12 brown o-rings (Viton) from Advance for two rails and put those on the bottom and left the black rings on the top. Now I'm almost as good as GM who has spent quite a bit of time optimizing the o-ring materials for the conditions. The pushlock supply and return o-rings are light green (not HNBR) or tan, probably Viton. Changing the conditions without also changing the materials might lead to early failure. Has OP checked into this before installing fuel heat? I think not. Then he goes and recommends it to everyone else who also haven't.
My only weakness to heat is the injector top o-rings which can be replaced with Viton.
GM now supplies a blue o-ring as a replacement for the black and brown/black o-rings over on RockAuto. Lesser but sufficient companies supply brown on bottom and black on top o-rings with instructions. The worst companies supply all one color hoping you won't have the car long enough to notice the leak.
Do use fuel heat if it works. Don't use it if it causes leaks when you're not watching.
Old 06-22-2008, 10:59 PM   #86
ShadowWorks's Avatar
I deadlifted 6 times my body weight when I was 24 years old (900 pounds), 33 years ago.
Thats is the most impressive lift
I'm 32 and can just lift 3 times my body weight! how thick was your back or do you just have the shortest torso in the world
Old 06-23-2008, 02:59 AM   #87
yea i was thinking the same thing....but i wont say impossible..my brother at 270 could dead lift 650lbs and thats a big strong mofo!
Old 06-23-2008, 03:02 AM   #88
omg! dude or old man 103 more lbs you could have been the world record holder for deadlift
Old 06-23-2008, 08:13 AM   #89
I have a friend called Mark Felix, he is an amazing guy and he can dead lifted 400Kg, he's in the World Strong man competitions and they all know he has one of the strongest back in the world, he is a brilliant guy, very nice attitude an humble.
Old 06-23-2008, 08:58 AM   #90
vxdude's Avatar
Send a message via Yahoo to vxdude
I cant wait to see some pics of chope's mod
vxdude is offline   Reply With Quote
Why did it take me so long to find this place? Baranfin Introduce Yourself - New member Welcome 6 05-31-2008 05:17 PM
hi new member here and ive got some sick ideas! csrmel Introduce Yourself - New member Welcome 6 10-18-2007 02:23 PM
