How does everyone set their timing? - Page 2 - Fuelly Forums
Old 04-09-2006, 06:19 PM   #11
Hehe, okay, that makes sense
Hehe, okay, that makes sense then.
Old 04-09-2006, 06:24 PM   #12
Send a message via AIM to molecule
oh and you dont want to
oh and you dont want to depin D4
you want to ground it...if there is even a pin in there...
i'm sure you get it...sorry...
oh and if you missed my edit on another post
i have an ecu cover for you...
dont put your chipped ecu at risk
i can barely stand the sight of that open ecu on your floor...
lol
BE ZEITGEISTED
molecule is offline   Reply With Quote
Old 04-09-2006, 06:26 PM   #13
Oh, ground it from the ecu
Oh, ground it from the ecu and not from the wire, silly me,
Old 04-09-2006, 06:38 PM   #14
double,triple,quadruple
double,triple,quadruple check that your cam timing marks and pulley timing marks line up exactly with the car off
set your dizzy at center with the bolts just loose enough to turn the dizzy by hand
start her up and heat cycle it at least once...
which is about 20 minutes or more until the fan comes on...
ground your service check connector (D4)
strap on your timing light
and make any nuance changes you wish
i recommend fixing any codes flashed on the check engine light first
BE ZEITGEISTED
Old 04-09-2006, 06:40 PM   #15
W00t for being code free.
Old 04-10-2006, 01:09 AM   #16
FE nut
diamondlarry's Avatar
Re: i also attended the
Originally Posted by MetroMPG
i also attended the diamondlarry school of timing adjustment. i figure i'm 3-5 degrees advanced over spec.
i have no idea if it's actually helping though. another scangauge test on the list...
Timing light? We don't need no stinking timing light!
*insert confident laugh here*
2007 Prius,
Team Slow Burn
Old 04-10-2006, 01:05 PM   #17
they are very helpful when
they are very helpful when your car isn't running in time due to other sensors manipulating it thru the code in the ecu...
more specifically...an advance timing light...
in fact...there's no other way to tell while your car is running if it is in time or not...
unless you are tapping into your ecu
but for all intents and purposes...yes...you dont need one...
*insert confident chuckle*
BE ZEITGEISTED
Could you add? blackfive Fuelly Web Support and Community News 2 01-11-2011 08:07 PM
Log your Cycling/Running on Fuelly? kclark987 Fuelly Web Support and Community News 1 09-21-2010 02:57 AM
Aerodynamic secrets revealed! Compaq888 Aerodynamics 4 06-28-2006 07:22 PM
BMW C.L.E.V.E.R. Concept MetroMPG General Fuel Topics 4 04-24-2006 11:59 PM
