How come no one Hypermiles with their VXes? - Page 4 - Fuelly Forums
Old 11-04-2007, 05:02 PM   #31
Matt Timion's Avatar
Originally Posted by James View Post
Or was that just your del sol that had the full belly pan?
I believe that Dan did a lot of EOC'ing in the hills of Pennsylvania
Old 11-04-2007, 05:20 PM   #32
krousdb's Avatar
I had the full belly pan on both the Del Sol and the VX. The Insight OEM tires made a measureable difference, about 3 MPG IIRC. Yes, lots of EOC in the hills of PA.
Old 11-04-2007, 05:36 PM   #33
Sigifrith's Avatar
Dan what size were the Insight tires you used on the VX? Also, VX wheels, or HX?
[SIGPIC][/SIGPIC]
Sigifrith is offline   Reply With Quote
Old 11-04-2007, 05:41 PM   #34
He ran HX rims, I forget the tire size though.
Old 11-04-2007, 05:42 PM   #35
krousdb's Avatar
HX wheels, 165/65/14 Bridgestone Potenza's. This size only is LRR. This is what was on the Honda Insight.
Old 11-04-2007, 07:15 PM   #36
1993CivicVX's Avatar
what mileage were you hypermiling your VX to?
three stripes the charm!
Old 11-05-2007, 04:40 AM   #37
krousdb's Avatar
See "The VX" in the garage.
Old 11-06-2007, 01:27 PM   #38
XFi
XFi's Avatar
I couldn't even pull close to the mileage that Dan was with the VX. Definately the master. The best mpg I did was 60 something (66?) driving it home when I bought it. That was drafting trucks till I got to DC. Still kind of wish I didn't sell it.
XFi
Join us for the November 22, 2008 Pennsylvania Meet at Cabela's!
https://www.gassavers.org/showthread....634#post121634
XFi is offline   Reply With Quote
Old 11-07-2007, 12:35 PM   #39
Wow, how come everyone else's VXes are doing not nearly as good? Not fair.
I assume you tested your odometer's accuracy?
Also, you weren't hypermiling. You were cruising on the highway between 55 and 75mph. I drive between 35 and 50mph with mild hypermiling techniques and I get about 54mpg which isn't even above the old EPA. I wonder how much difference LRR tires will make and 60 PSI.
Old 11-08-2007, 05:31 AM   #40
krousdb's Avatar
The SuperMID I was using showed % of distance with the engine on. Mine would show about 50% on my daily commute. So for 25 of the 50 miles, the engine was off, coasting. I spent lots of time choosing the route. Climb steep hills, coast down for miles. Never had to use the brakes. Sweet!
