honda insight undertray images - Fuelly Forums
Old 03-22-2006, 07:15 AM   #1
http://www.dennisjudd.com/archives/000851.html
a few good shots of the undertrays (and the problems the owner had with them)
Old 03-22-2006, 12:35 PM   #2
kickflipjr's Avatar
I never really though about
I never really though about that. It would be anoying doing oil changes.
2008 EPA adjusted:
Old 03-22-2006, 01:36 PM   #3
Top-Mounted Filter, but Oil Pan...
I saw an interesting thing at the auto show. The Toyota FJ Cruiser has a top-of-the-engine mounted oil filter (on an aside - I'm afraid this rugged outdoorsy type will be relegated to mall and high-school parking lots instead of its intended purpose). Anyways, I know it's probably harder to do, but the filter could probably be re-routed to an easier location (not sure how to retrofit the old location vs. new, but I'm sure it can be done with some moderate technical skills). Furthermore, could a hole be drilled in the baffle and have a funnel with a tube run through the hole to catch the oil to drain; and depending on the angle, with a ratchet extender to loosen the plug (maybe two holes, one to drain and one to get the ratchet up in there)? The hole(s) could then be plugged with a commercial snap-plug to maintain the low Cd. It might make a mess if not done easily, but it could reduce the continuing pain of taking the shroud off at every change. Just brainstorming (again)...
Help...MPG calculator not working djquik1 Fuelly Web Support and Community News 1 10-18-2010 05:57 AM
Keep track of gallons burned, not MPG. jkp1187 Fuelly Web Support and Community News 2 05-10-2009 01:10 PM
Support for motorbikes wrighth1 Fuelly Web Support and Community News 9 08-18-2008 07:11 AM
Ever wonder how wind will effect your mileage? Lots of interesting Prius info krousdb General Fuel Topics 4 02-08-2006 08:49 PM
My paint job saga... with pictures of the finished product Matt Timion General Discussion (Off-Topic) 9 01-04-2006 08:16 PM
