Honda Guys: Stock flywheel weight stuff - Fuelly Forums
Old 05-14-2006, 08:45 AM   #1
Civic VX def comes with 15 pound as opposed to 18 pound, and I just confirmed the Civic CX (92-95) to be the same.
So there.
Old 05-14-2006, 11:34 AM   #2
Matt Timion's Avatar
Re: Honda Guys: Stock flywheel weight stuff
So there.
Do you suspect that the JDM d15b (d15z1 clone) is the same? I really don't want to remove my flywheel just to weigh it.
Old 05-14-2006, 11:36 AM   #3
If you want a trick to get
If you want a trick to get it off use your breaker bar to brace the crank pulley and then put a wrench on the flywheel bolt and stomp the wrench,
I have no idea though, really no way to tell I don't think.
Old 05-14-2006, 10:24 PM   #4
philmcneal's Avatar
i wish i had a lighter
i wish i had a lighter flywheel then maybe my shifts can be so much faster... but that would mean starting out there is a higher potenial for a stall correct?
Old 05-15-2006, 05:30 AM   #5
Moderator
GasSavers_DaX's Avatar
Re: If you want a trick to get
Flywheel bolts come off easily with an air impact wrench (even a weak one) with no bracing of the crank.
Old 05-15-2006, 05:54 AM   #6
That's the reason it's a trick and not the proper way to do it,
I don't have any air tools and I really didn't have any air tools at a stranger's house two hours from home.
Old 05-15-2006, 05:54 AM   #7
The rpms drop faster, yes, but most people say they adjust to the change very quickly.
Fuelly for Android? tommyz Fuelly Web Support and Community News 3 04-08-2010 03:22 AM
More flexibility in Fueling up Dustin Fuelly Web Support and Community News 0 08-13-2008 02:53 AM
feature request: updates via text message savraj Fuelly Web Support and Community News 1 08-13-2008 01:21 AM
Could it be? 95metro General Discussion (Off-Topic) 5 07-07-2006 02:42 PM
