Honda CRX HF Gearing ...and/or engine swap - Fuelly Forums
Old 08-31-2006, 08:46 AM   #1
Send a message via AIM to Brian D.
Smile Honda CRX HF Gearing ...and/or engine swap
I only recently learned why my HF screams @ highway speeds.
Apparently there were 2 different transmissions available for
the HF (the "49 state" and the other one). My last HF had
the good tranny, which turned @ 2250RPM at 70MPH. The one I
have now is about 500RPM higher. I'd really like to swap that
5th gear for the taller one...but where can I get one of
those?
GAS GSLR
Brian D. is offline   Reply With Quote
Old 08-31-2006, 08:56 AM   #2
GasSavers_Ryland's Avatar
www.car-part.com seems to have them, alot of them, cheapest/closest to me is $100 for a whole tranny.
it looks like there were 3 trannies in the HF, a "normal" one, a high altatude, and a californa only, I suspect you have the high altatude one.
Old 08-31-2006, 09:13 AM   #3
HF Tranny
Worst part is that unless I can get some inside information
from Honda Motor Co., it's just going to be trial & error
when I just start pulling gears out of HF's....as I know of
no method to deciphering which will have the tallest 5th
gear. I'll likely wind up with the same as what I already
have.
GAS GSLR
Old 08-31-2006, 09:35 AM   #4
Yay, time for me to be of use! But first of all, introduce yourself in our intro forum,
Old 08-31-2006, 09:35 AM   #5
http://crxmpg.com/8891dgearing.html
As you can see, the difference is not in the gears, it's in the final drive!
Old 08-31-2006, 09:43 AM   #6
Great! Your from my (weekend) homeland...sort of. I drive from VA Beach to Monmouth Cty, NJ every weekend. Anyway, I don't know a whole lot about transmissions...and never cracked one open. What's the deal with the final drive? I sure wish I had my old '91 HF...now THAT was the tranny/gearing to have. Instead I've got this crappy gearing that makes me work like hell just to obtain 47MPG. I used to get 50-55 MPG in that old '91. Okay, what's my solution?? I'd love to go 6-speed...but somehow I don't see that as feasible. **Are you a Honda head? If so I've got more questions for you (FE questions).
GAS GSLR
Old 08-31-2006, 09:48 AM   #7
6 speed isn't feasible unless you feel like fabbing up some awd b stuff, or awd d stuff, or going k series,
Anyway, the solution that's easiest would just be to buy another HF transmission, but get one that's 49 state this time.
Fire away with your honda questions!
Old 08-31-2006, 10:07 AM   #8
Nice! Here goes: As much as I've been wanting to get this better (taller gear/final drive) tranny back again, I would still have to install it in this 63HP CRX HF of mine. I can't help but wonder though, what if I get my hands on the Civic VX ('92-95) D15Z1 motor...which makes 30+ HP than my HF does.....and couple that with the fact that I'd be dropping it into my HF body, which is ~200LBS lighter than the VX (not sure about motor weight difference). If I then couple that with the gearing from my HF tranny...and larger diameter (but lightweight, of course) wheel/tire combination....wouldn't I be in a major sweetspot? I would figure 92 HP would help me make decent highway power (on inclines & whatnot) where the little HF motor struggles. Wouldn't this combination be the perfect platform to work with for super high EF?
GAS GSLR
Old 08-31-2006, 10:08 AM   #9
Yes, you've indeed figured that out well. It is the perfect plaform, and I really wish I had one but no luck finding one in good shape around my neck of the woods. I think there's an importer around you though, iono.
Old 08-31-2006, 10:14 AM   #10
Ah. I rarely see these damn VX's. Saw one last night at the supermarket, but was too late to leave a note on the window. If I do track one down I'm going to be all over it. So should I assume the HF tranny bolts directly upto the VX motor? (just wasn't sure about that). Sorry to chew your ear off, but I only just found this site after 6 years of being an HF owner.
GAS GSLR
Please Add Time of Day to Fuel Up Screen xoraclez Fuelly Web Support and Community News 1 03-29-2013 08:03 AM
Help...MPG calculator not working djquik1 Fuelly Web Support and Community News 1 10-18-2010 05:57 AM
gasoline and veggie oil, to much time to think. GasSavers_Ryland Experiments, Modifications and DIY 35 06-30-2008 06:20 PM
an increase of 20mpg cost me... chesspirate General Discussion (Off-Topic) 31 01-22-2008 04:22 AM
VX -- Del Sol engine swap GasSavers_moses General Fuel Topics 28 01-06-2006 04:38 PM
