08-31-2006, 10:18 AM
Oh, it bolts right up. And don't worry, I'm here to help!
08-31-2006, 10:30 AM
Nice writeup on the ride-height lowering - using the lowering springs. However, didn't I recently read somewhere that if you use the stock shock/strut tubes for lowering the car --that they don't last very long at all?
GAS GSLR
08-31-2006, 10:35 AM
It's true depending on how much you lower, I'm running tokico illuminas now though,
08-31-2006, 11:03 AM
I see. So anyway, what size tires/wheels are those VX's? According to this website: http://www.miata.net/garage/tirecalc.html if I change my current setup of 175/70/13's to 185/75/14's, my speedo will be underexagerrated by 6MPH, therefore increasing (to my knowledge) my effective MPG. Of course I'll have a slightly larger contact patch with the 185's. But probably not enough to make a difference. As long as I can find a lightweight setup I'll go for it. As it stands right now I only run with +2 PSI above MFG recommendations. Let me know how your car rides with stiffer suspension COMBINED WITH high-inflated tires. Thx.
GAS GSLR
08-31-2006, 11:06 AM
Car runs perfectly, nice and tight. Anyway, I think the VXs are 175/70/13, but not exactly sure. The HXs are the 14s, both are good, with the HXs you can run the insight LRRs though, so yay.
08-31-2006, 11:10 AM
And with the insight tires at 165/65/14, you have the same diameter as the 175/70/13's. No underexaggeration!.
08-31-2006, 11:12 AM
 dan.
08-31-2006, 11:14 AM
Originally Posted by SVOboy
 dan.
You are gonna sprain you thumb Ben.
08-31-2006, 11:22 AM
#19
It's not my fault, you're just TOO COOL!
08-31-2006, 11:28 AM
#20
sorry, I meant to express my definite WANT for the underexagerration. As long as I can run a larger diameter setup I'll be running a higher MPH at a lower RPM (even though my speedo won't show it). I DO want this. Call it a cheap way to change my effective gearing since I've got the larger circumferance, taking longer to complete a single revolution in a given gear. I want this. I'm sure I'm not the only one who does.
GAS GSLR
