Highest MPG V8? - Page 2 - Fuelly Forums
Old 05-22-2008, 09:45 PM   #1
The Vette and Camaro both, with the LS/1 V8 had that massive .5:1 6th gear which took revs down to ~1400 @ 65. While they were never actually rated at 32mpg, many owners of both cars have touched 30+ and most can consistently and easily pull better than 27.
LT/1-equipped cars like the Cadillac Fleetwood and Chevy Impala SS, among others, were capable of mid-20's, not bad for a 4000lb+ V8 car. Similarly, the Cadillacs with Northstar V8's are known for getting ~27mpg on the open road with little effort.
Some folks have swapped EFI onto their vintage Mustang small blocks and together with a 5-speed manual swap get 25+, some even claim 30 highway.
My best was 22mpg in my '68 Mustang. It had a 302 and no overdrive, but it had the tallish 2.73:1 rear end and the hardtop body was the lightest bodystyle weighing in at ~2750lbs. I got that on the flats of the Central Valley, CA, doing about 60 on Interstate 5 with freshly aired up tires. It was a bit of a freak tank, I usually got 18-19mpg at that speed. May have been the Flying J pump I got gas at...
'00 Echo - DD
'11 Kia Rio - Wife's DD
Old 05-23-2008, 05:27 AM   #2
I knew there was a good reason to drop a Northstar in my minivan....
Old 05-22-2008, 10:58 PM   #3
I've heard 34 from a C5 z06 owner. Don't know the particulars of it. I know that they have a lean burn system in the PCM. I'm sure with hptuners more could be squeezed out of it.
Old 05-23-2008, 02:37 AM   #4
My dad swore that he could get 25 mpg with his '66 Dodge Polara, 318 V-8, two barrel carb. But I never personally verified that.
Old 05-23-2008, 04:14 AM   #5
My dad owns an '03 Corvette, so I know for a fact that they can get 30+ mpg if you drive it easy. The RPM's are so low while cruising. I think at 55mph it only turns something like 1500, but tons of power on demand, if/when you need it.
96hb is offline   Reply With Quote
Old 05-23-2008, 07:20 AM   #6
Site Team
Originally Posted by 96hb View Post
My dad owns an '03 Corvette, so I know for a fact that they can get 30+ mpg if you drive it easy. The RPMs are so low while cruising. I think at 55mph it only turns something like 1500, but tons of power on demand, if/when you need it.
Having the RPM so low just astounds me. You still need some power to move the car, but I guess if you have so little aerodynamic resistance the engine doesn't have to produce much torque, so it's okay to run it "down in the mud". I'd be curious to know what kind of timing numbers they use under load at 1500 RPM, since the piston speed is so slow.
I guess a lockup converter is also helpful with the automatics (crown vic & northstar), of course the 5-speed manual (i.e. mustang) being the odds-on favorite.
-Bob C.
Old 05-23-2008, 07:52 AM   #7
It's not that shocking that a Vette can do 55 mph at 1500 rpm, when you consider that a VX is only turning 1852 rpm at that speed. 1.5 liters.
Old 05-23-2008, 08:25 AM   #8
If you look at the torque on that engine (2001 Corvette test results) you'll see why the engine is able to turn so low.
Obscene amounts of torque everywhere. Over 300Ft-Lbs as low as 1500 rpm!
It's also why this car can cost only 65K and not only keep up but in a lot of cases beat 200K+ sports cars in performance, feel and fuel economy. This is actually the only car GM makes I would buy.
- Kyle
Old 05-23-2008, 07:21 AM   #9
Site Team
I've heard lots of claims like that also, but they also sounded like "wives tales" to me too...
-Bob C.
Old 05-23-2008, 05:14 AM   #10
Yeah. I've always heard a lot of good about the FE that LS1 could get
Bad Gas...oline 95_corolla General Fuel Topics 22 05-11-2007 08:01 PM
