I was just thinking the other day... And this really doesn't apply to me, as I'm very close to sea level. But for people driving at higher altitudes....
When we measure tire pressure, we're measuring gauge pressure - the difference between local atmospheric and inside the tire. So, given a higher altitude, tire pressure will appear higher than the same amount of air inside the tire at sea level.
So gauge pressure changes, but the amount of force your tire must hold up doesn't (lets say constant gravity
That would mean, under inflation of tires is likely more common at higher altitudes EVEN THOUGH gauge pressure is within the normal pressure range...
Okay, we're not talking about much here...
Sealevel: ~ 101kPa
5,000 ft: ~ 84 kPa (difference of 2.9 psi over sea level)
10,000 ft ~ 69 kPa (difference of 4.6 psi over sea level) <--- seriously, that's one high city
Just something to chew on because if every bit didn't count - I'd be driving an SUV
