Hho - Page 2 - Fuelly Forums
Old 06-17-2008, 06:33 PM   #11
GasSavers_Russ's Avatar
Originally Posted by Ford Man View Post
Is your site an informational site or sales? What is the web address? How about including a link.
COMPLETELY INFORMATION
Wouldn't dream of charging for something we should all own
We need to make this as open source as possible, i am doing it all out of interests
I also have information on my HH-O Forums
GasSavers_Russ is offline   Reply With Quote
Old 06-17-2008, 06:34 PM   #12
And again that link is http://hho.kicks-a s s.net without the spaces
Thanks for your time
Russ
Old 06-17-2008, 06:36 PM   #13
Hodag'stiva's Avatar
Used up all my tin foil on headgear. Will get some tomorrow, if the Illustrious Leader will let us leave the compound.
B
Forty Miles to the Gallon, Twenty Year Old Technology
Hodag'stiva is offline   Reply With Quote
Old 06-17-2008, 06:41 PM   #14
B
I used mine lining an old football helmet so the Gov't spy satellites cannot read my mind.
Old 06-17-2008, 06:43 PM   #15
Tin Foil
B
lol belive it or not i did something simular the other day, amassing stuff.
if your keen to try it you can just use copper wire but it erodes quickly the closer the two wires the more production you will recive but the more amps you will draw
Old 06-17-2008, 06:44 PM   #16
Hateful's Avatar
Send a message via AIM to Hateful
B
Good one; I think the site is gonna be okay after all.
Hateful is offline   Reply With Quote
Old 06-17-2008, 06:45 PM   #17
Angry Y didnt i
Y didnt i think of that ?
and all this time ive been wasting my time on trying to get more for my money?
i was disgusted today to get 7.5 leters of petrol for ?10
Old 06-18-2008, 05:24 AM   #18
Site Team
Originally Posted by Russ View Post
(FOR ALL THE PEOPLE THAT DON'T BELIEVE)
Get a 12v battery and 2 bits of tin foil connect the battery to the tinfoil via wires and space the tin foil with kitchen cloth
I did this as a seventh grade science project, but I still haven't seen real evidence that it can be a true gas-saver. Not trying to be a hard-***, but I think the rest of the crowd around here also has yet to be convinced.
-BC
Old 06-19-2008, 02:33 PM   #19
Come here and ill show you,
-BC
Yuh your telling me,
I am convinced of this as i have had a mini moto engine idling off of the stuff and i have also made a blow torch,
if you truly believe that it dose not work .please try it, its as simple as two bits of tin foil an old 12v charger and some salt. put a rely small amount of washing up liquid (and i mean small) and it will catch all the bubbles. you can then light them. it is very explosive, it takes seconds to set up and surprising results.
please do try it if you ' believe me and then leave your posts here. if it dose not work ill be a monkeys uncle.
Russ. . .
Old 06-19-2008, 04:01 PM   #20
Where was the power for the mini-moto engine coming from?
The thing that gets me is how it's supposed to increase fuel economy so drastically but you can't just run a car off of it. If any sort of outside fuel source like this can increase something even a little on a small scale, it makes sense(to me anyways) that a unit used in say a v8 car could power a little 3.5hp briggs standalone.
The reason I come to that conclusion is because the way this is supposed to be working is the H2 and O2 in the chamber are supposed to create more energy when they burn than you need(increased mpg) to do the initial electrolysis, count for the lack of thermal efficiency in the engine and mechanical to electrical losses in the alternator.
If you do the numbers(and to keep you HHO freaks happy I'll use the high numbers) electrolysis of water hovers around 50% efficiency, alternators typically hang around 70% when they are new and get progressively worse over time, and the most efficient of engines have a thermal efficiency close to 30% under ideal conditions.
This whole (extremely simplified cycle) is only about 11% efficient if I round up. With an 89% loss in the system as a whole, how do you get an increase in mpg? At 12v and 5 amps, you have a 60 watt draw on the electrical system. To break even with that draw the HHO needs to generate an additional 1900BTU. That's 1.5% of the BTUs in a single gallon of gasoline to break even.
I just don't get it. Starting with water and ending with water while being able to get extra work out of the process. Sounds like a perpetual motion machine to me...
- Kyle
A shot with a mix... GasSavers_SD26 Diesels 23 03-13-2008 06:20 PM
How to achieve window sticker fuel economy in a CIVIC VX???? panamacolin General Fuel Topics 14 02-25-2008 05:19 PM
Air scoop for mpg? ZugyNA Experiments, Modifications and DIY 10 12-05-2007 10:40 AM
Are you a believer in Peak Oil theory? Peakster General Discussion (Off-Topic) 47 12-01-2007 06:49 PM
BIG car Andy-Paul Transmissions and Running Gear 30 10-24-2007 02:25 PM
