Hho? - Fuelly Forums
Old 05-18-2008, 08:55 PM   #1
friz's Avatar
Hho?
Any quantifiable evidence that this works. Mileage logs? Anything? I find it odd that these MPG sites all let them advertise but I hear nothing about anyone using the "technology".
I used to curse when I got stuck behind you guys on a two lane blacktop. If you can't beat em?
friz is offline   Reply With Quote
Old 05-18-2008, 09:42 PM   #2
GasSavers_Ryland's Avatar
I haven't even seen ads that claim that it improves mileage without being extreamly vague, or by trying to confuse people that might not understand what they are selling buy using weird terms instead of being straight forward.
I've made hydrogen, I've used a $6,000 hydrogen generator that ran a torch, I've seen engines run off hydrogen, the amount of energy needed is great, the amount of hydrogen produced is very small.
So far all of the gains I've heard of could be attributed to the placebo affect, if the gains were real then you should be able to turn on the electrolysis set up while going down the highway with cruse control on and see a change on an instant mpg read out and from what I have seen no one can do that.
Old 05-19-2008, 04:27 AM   #3
GasSavers_BEEF's Avatar
several people on here are trying to tell other that it is very viable and works very well....none of which have gas logs.
I am going to stick to the stuff that works. grill blocks, aero mods, driving style, etc...
I advise others to do the same unless it is simply an idle curiosity. I wouldn't put much money into trying to make it work.
Old 05-20-2008, 07:17 PM   #4
friz's Avatar
That's what I thought.
Old 05-20-2008, 08:59 PM   #5
bockwho's Avatar
ive built a few here at work given them for guys to try im still baselining my civic hx i will install once that is done and throw some numbers.
kb
[/url]
bockwho is offline   Reply With Quote
Old 05-21-2008, 08:10 AM   #6
friz's Avatar
kb
Thanks, It's good to see someone wants to put this to an honest test.
A shot with a mix... GasSavers_SD26 Diesels 23 03-13-2008 06:20 PM
Air scoop for mpg? ZugyNA Experiments, Modifications and DIY 10 12-05-2007 10:40 AM
Are you a believer in Peak Oil theory? Peakster General Discussion (Off-Topic) 47 12-01-2007 06:49 PM
Brake Puck Return Tool - Home Made Mayhim Experiments, Modifications and DIY 0 11-27-2007 12:33 PM
BIG car Andy-Paul Transmissions and Running Gear 30 10-24-2007 02:25 PM
