Originally Posted by 2TonJellyBean
I'm not sure how fast you "need" to go or how flat the terrain is or how much you need to start/stop but unless it's a steady speed flattish commute, I'd be tempted to give weight reduction some serious attention.
Absolutely! This car will be a stripper!
I will probably leave in the back seat for utility, but most panels, all carpeting and sound deadening material will be removed. I plan to get a little crazy with this one. Since I drive so much, I think I will leave in the radio this time.
I wonder what the weight savings of the rear and rear side glass would be. Do you know if anyone on the site replaced glass with plexiglass? Hmmmm...
Been thinking about saving weight and rotating mass by replacing brakes/calipers with a retro year escort set up that is smaller.
Off the subject (sort of)...I was thinking of adding more weight with a Solar Panel installed on the roof to off set the 50% reduction underdrive pulley I am thinking of. They are kind of heavy, but I think the benefit of the pulley would off set this.
