Heated fuel lines revisited - Fuelly Forums
Old 04-18-2006, 07:04 PM   #1
zpiloto's Avatar
I did a search and notice that heated fuel lines has been discussed on this site but couldn't tell if anyone try it. When I looked in the top 10 only one mentioned having heated fuel lines. I saw over a 3% increase in FE when I installed them. Is anyone using them or is my gain unusuall?
Old 04-18-2006, 07:15 PM   #2
What's your setup and all
What's your setup and all that? Is this scangauge verified or just tank to tank?
Old 04-19-2006, 03:15 AM   #3
zpiloto's Avatar
I'm running 3/8" copper
I'm running 3/8" copper tubing along the top of the radiator hose wrapped with aluminum foil. Water temperature runs between 190-205. Yes it was runs with the scangauge.
Old 04-19-2006, 03:46 PM   #4
Not bad, I'll have to add
Not bad, I'll have to add this to my testing list for when the superMID shows up. Got any pictures?
Old 04-20-2006, 11:36 AM   #5
zpiloto's Avatar
No, I don't have the
No, I don't have the technology for that yet. Soon though.
Old 04-20-2006, 11:50 AM   #6
can you describe how you ran
can you describe how you ran your test? do you still have the data? it may be worth writing up an experiment summary. i'd be interested to know the details.
Old 04-20-2006, 01:15 PM   #7
zpiloto's Avatar
Here’s the data taken from
Here’s the data taken from the Scan Gauge. I did 3 runs on my usual 41 mile test loop. It was an A-B-A run. Temps mid 60’s winds south at 10-15 warm engine.
Without the heated lines
MPH Avg 40
Gal Used 1.1
MPG 34.2
With heated fuel lines
MPH Avg 40
Gal Used 1.1
MPG 35.4
MPH Avg 39
Gal Used 1.1
MPG 34.4
Old 04-20-2006, 01:30 PM   #8
Compaq888's Avatar
this proves they work
Old 04-20-2006, 03:18 PM   #9
Matt Timion's Avatar
Re: this proves they work
Actually with a sample that small it doesn't prove anything.
