has anyone tryed to run motors on less cylinders on the highway - Page 3 - Fuelly Forums
Old 06-20-2009, 04:54 PM   #21
theclencher's Avatar
Originally Posted by kamesama980 View Post
You give me a few million bucks to throw at blowing up engines and I'll give you hard numbers. Till then I'll stick to stating my speculations, right or wrong. If I am wrong, and it certainly happens, it's usually because I lack info about something and I'm just going on logic. I do very much like to fill in those gaps so when pointing out when I'm wrong by all means feel free to explain at length.
You don't need a million $ or even any experimentation. Just go online and find out how the various cylinder deactivation systems work then get back to us.
NONE of the materials I've read indicate "cycling" of dead cylinders amongst them all as a means of dealing with your speculative "problems".
There IS a system that cycles dead cylinders, and that is the Cadillac Northstar limp-home mode for the circumstance of coolant loss. It does not work as an economy device.
It is not unknown for car engines to have experienced dead cylinders, mostly due to ignition problems. Cylinder heads didn't crack, head gaskets didn't fail, etc. etc. etc. Power and economy went down, though, and pollution went up. That's about it.
P.S. GM says wear differences between live and dead cylinders is a non-issue.
Tempo/Topaz:
Old EPA 23/33/27
New EPA 21/30/24
F150:
New EPA12/14/17
Old 06-24-2009, 10:03 PM   #22
Nobody does homework anymore eh?
Tempo/Topaz:
Old EPA 23/33/27
New EPA 21/30/24
F150:
New EPA12/14/17
Old 06-25-2009, 10:36 AM   #23
kamesama980's Avatar
Not for something as trivial as this. not enough hours in the day. I wanted to get you to chime in with what you know instead if just "you're wrong" and nothing more... to end the speculation
-Russell
Old 06-25-2009, 06:29 PM   #24
Hey, I did the research and put it ALL up once upon a time, where it appeared to be ignored. I used to do that a LOT. Now, I refer people to Google, because that is largely where my research starts and alls y'alls have the same access to it as I.
Tempo/Topaz:
Old EPA 23/33/27
New EPA 21/30/24
F150:
New EPA12/14/17
Retire a Vehicle pb Fuelly Web Support and Community News 1 11-11-2008 04:30 PM
Another reason for better summer mileage, and a question. omgwtfbyobbq General Fuel Topics 14 03-13-2007 07:45 PM
