half full or half empty tank? - Fuelly Forums
Old 01-16-2008, 05:55 AM   #1
Should you expect better milegae filling up when your tank gets to the half full mark? (always having atleast a half a tank). If so why? What about the extra weight of a full tank?
Also, is there any truth to filling up in the morning when the gas is cooler for more density?
chris Adamson is offline   Reply With Quote
Old 01-16-2008, 08:50 AM   #2
kamesama980's Avatar
as opposed to what? waiting till it's on E?
with a 20 gallon tank and 10 gallon halfway mark you'll be running about what? 7lb/gal so 70 lbs difference from full or empty....maybe 1/10 mpg gain. nothing outside the normal variation.
as for filling up in the AM: that's logical but not thought out urban myth. gas is stored many feet underground and the temperature doesn't fluctuate much down there. ever been in a cave? the mouth is close to ambient temp but get a hundred feet in and it'll vary 5 degrees between a 90f day and a 0f winter night. even in the northern US permafrost only reaches a few feet down through the soil.
-Russell
Old 01-16-2008, 08:57 AM   #3
I think the myth about filling at halfway vs. filling at E is all due to variations in gas tank designs.
My Saturn for instance APPEARS to go through gas after the halfway point VERY quickly. Take into consideration the design of the gas tank and you find that halfway isn't exactly 6.25 gallons, it's probably closer to 5 gallons or less.
John
'09 Saturn Aura 2.4L
'96 Chevy C1500 (5.0L 5sp)
'01 KTM Duke 2
Old 01-16-2008, 10:41 AM   #4
Moderator
GasSavers_DaX's Avatar
In addition to what kamesama980 said, I think that modern gas pumps compensate for fluctuating temperatures.
99% of the time I only fill when below E, and like Project84 said, the fuel level APPEARS to drop rapidly from 1/2 tank to about 1/8 tank, then slows way down again.
Old 01-16-2008, 12:09 PM   #5
palemelanesian's Avatar
350 data points, on my daily commute, since April. Varying weather conditions.
125% is from topping off, when the needle is above the F on the gauge.
0% has the fewest data points, and as such is somewhat suspect. Sometimes I have to fill up from 1/2 or 1/4, for a trip or something.
Tank Fill / Avg mpg
125% / 54.0 mpg
100% / 54.5 mpg
75% / 55.2 mpg
50% / 55.5 mpg
25% / 55.5 mpg
0% / 55.2 mpg
Old 01-16-2008, 12:13 PM   #6
Thermactor's Avatar
I only fill up my tank halfway because it's an easy 100 lbs saved. And I'm poor and dont wanna fill up the whole tank.
Thermactor is offline   Reply With Quote
Old 01-16-2008, 01:35 PM   #7
jadziasman's Avatar
In winter, in the freezing north - home of the climatically challenged, it's smart to keep the tank at least half full. You never know when or where an old car will decide to break down and it's really nice to have a lot of gas to burn if you need to wait for help to arrive.
Old 01-16-2008, 04:11 PM   #8
More related to reliability then fuel economy I have always had at least half a tank simply to stop the pump sucking up the rubbish which settles in the bottom of the tank.
It also allows you the option to add fuel at your choice not that dictated by a flashing light on the gas gauge.
If you are about to run out then you pay whatever the gas station asks since you have little choice.
Also I like to fill at places having a high turnover since the fuel is normally sitting for less time than some place off the main traffic flow where the fuel may sit for ages before it is used and replaced.
By the way the differences in economy posted by PaleMelanesian amount to less then I MPG in 55 or between one and two percent.
Pete.
GasSavers_Pete is offline   Reply With Quote
Old 01-18-2008, 09:29 AM   #9
The other part of the myth than spawned my question was the claim that extra airspace in the tank was a bad thing because there is too much room for vapor. Isnt the tank a closed system? So would one get better mileage on a full to half tank or half to empty tank?
Old 01-18-2008, 09:41 AM   #10
Hateful's Avatar
Send a message via AIM to Hateful
I get slightly better mileage with the tank half full, but after I drive out of my way to stop an extra time or have to get gas at a higher priced station, it comes out the same. I ride without the front passenger seat most of the time to make up the weight difference; once it started getting cold I didn't want to pump gas in the cold cold wind any more than I had to.
Vapors aren't going anywhere but back into the liquid when it cools off; providing it got warm enough to evaporate to begin with.
Hateful is offline   Reply With Quote
Vehicle year - 2013 Prodigal Fuelly Web Support and Community News 6 12-21-2012 03:59 AM
truck aeroback kitcar Aerodynamics 32 12-04-2009 04:03 AM
I don't think I can last w/o A/C for much longer... DrivenByNothing General Fuel Topics 12 06-06-2007 08:31 PM
Innovate LC-1 WB O2 sensor Installed CoyoteX General Fuel Topics 12 04-15-2007 04:26 PM
Just fired up the swamp cooler Matt Timion General Discussion (Off-Topic) 13 08-04-2006 05:43 AM
