Got my work cut out for me. - Page 2 - Fuelly Forums
Old 01-14-2010, 02:34 PM   #11
You can always velcro the Scangauge onto the steering column like I did on my Sierra, and the Scangauge is much more than a set of gauges. It allows you to monitor stuff that the dash gauges don't display. For example, I often watch the O2 sensor output so I can confirm when the engine is in DFCO.
Old 01-14-2010, 02:54 PM   #12
Yes, but as far as the law is concerned it's just another set of gauges. (hint hint wink wink)
Also Ill second mounting it on the column. That where I put mine. Wrapped the 6ft cord around a couple times then plugged 'er in.
Bubba Bob is offline   Reply With Quote
Old 01-14-2010, 03:05 PM   #13
I velcro'ed mine to the column, and then ran the cable along the top of the column to where it goes into the dash. I then ran the cable behind the dash to the OBDII port.
Old 01-14-2010, 03:30 PM   #14
I too run mine inside the dash. Mine is located on top of the dash near the A-pillar.
Old 01-15-2010, 08:02 AM   #15
Just a note from personal experience. I had done headers on my 5.9 to replace the ugly log style manifolds and it helped quite a bit as far as MPG goes. I'd watch after the intake, my brute force apparently does let cooler air get to the engine and it hasn't helped my mileage at all, in fact, it is worse.
If you don't put on the metal heat shield you might do better though.
- Kyle
Old 01-20-2010, 10:03 AM   #16
GasSavers_FordF150's Avatar
I'll make sure to use the scanguage before and after to know if the brute force is worth keeping.
I just flushed the system and put some fuel addative from Lucas to clean out the injectors. Got worse FE for that tank but since then I've been averaging about 12.5 mpg which is up 2.5 mpg, pre cleaning.
GasSavers_FordF150 is offline   Reply With Quote
HHO Generator and O2 Sensor earthbound1 General Maintenance and Repair 1 06-30-2008 09:33 PM
Pictures of 2007 Honda Accord Hybrid in Showroom before "Tigerhonaker" took it HOME: tigerhonaker Hybrid Vehicles 7 08-26-2007 12:08 AM
Visual representation of airflow behind car landspeed Aerodynamics 6 12-04-2006 02:58 PM
Gaslog entry blues Spule 4 General Discussion (Off-Topic) 5 10-25-2006 07:03 AM
Whats your concentration factor. zpiloto General Fuel Topics 15 09-30-2006 05:28 PM
