Got my Scangauge-pretty eye opening - Page 3 - Fuelly Forums
Old 05-22-2008, 12:33 PM   #21
Originally Posted by R.I.D.E. View Post
If the grade is fairly steep and sustained I woud actually reach my highest pulse speed at the bottom then gradually lift the pedal as I try to maintain the same speed regardless of the fact I am going uphill or downhill. Constant speed will give you the lowest overall drag, by avoiding the higher speeds exponential increase. Vertical climb no more than 60 feet in this example.
That's my experience, we have few shallow grades here, I have over 70 feet of vertical climb on two hills just to get out of my small subdivision. About 230 feet vertical climb to get to the closest shopping.. 2.6 miles away.
With a racecar on a 16' tandem axle trailer behind an Expedition @ 8800 lbs total weight I can get 17 mpg at 60 mph average speed using this technique.. Do most of the accelerating at the bottom of the valley, gradually slow going uphill and coast downhill.
Put the cruise control on and go the same average speed and it's more like 14 mpg.
Old 05-22-2008, 12:56 PM   #22
Cruise control can only react not anticipate. If they had any brains they would put a level in the system to determine the immediate sope of incline or decline and modify the program.
They could also put in an auto hypermile program.
I thought once I would put a bungee cord on my Toyota automatic to pull it out of drive unless I forced it into drive. It spent most of its time in neutral anyway .
regards
gary
Old 05-22-2008, 01:00 PM   #23
The Expedition is not mine so I hesitate to put it in neutral for coasting, I could probably squeeze another mpg or two out of it if I did that..
Old 05-22-2008, 01:18 PM   #24
Dont think it will hurt as long as you leave engine running, then primary pump is working which controls shifts as well as lubrication.
I would make darn sure it was OK. Most owners manuals tackle the issue when you look up towing recommendations.
Some auto trannys will flat disintegrate if you tow them without the engine riunning.
regards
gary
Old 05-22-2008, 04:32 PM   #25
Originally Posted by samandw View Post
In scenario #1 we average (17+38)/2 or 27.5 mpg at 60 mph.
In scenario #2 we average (26 + 35)/2 or 30.5 mpg at say 58 avg mph.
It's possible you did better simply (or at least partly) because you slowed down. Slowing down is pretty much a sure-fire way to enhance mpg. But eventually you reach a limit, with this tactic. The trick is to figure out how to operate more efficiently, which means enhancing mpg without sacrificing distance or average speed. Efficient operation generally means large throttle openings, which is inherently counterintuitive.
Test 2: decelerate up hills, accelerate down
Depending on the circumstances, this tends to happen naturally. But if you take this too far, you end up with a large variance between your min speed and your max speed. A moderate variance is OK, but when it's too large it tends to create various problems. The extra aero drag was mentioned. It's also more likely to annoy other drivers, and more likely to create a problem with speed limits.
Originally Posted by bkrell View Post
the numbers were silly-like 9 uphill then 55 mpg or so downhill.
That's typical of what happens with an instrument that reports instantaneous mpg. There are wild swings. The implied strategy is obvious: never drive uphill, always drive downhill. Kind of like the classic stock market advice to buy low, sell high. Easier said than done.
The downhill didn't change much when I dropped the speed and got close to 26 mpg uphill.
From 9 to 26 is a big jump, and I can't explain that. But maybe it's real, so keep doing it and see what the results are when you fill.
The instantaneous information is helpful, but it becomes more valuable when you put it in the context of a broader interval, like a 'trip' (however you define that).
Does the fact that I have a turbo car make a difference?
Good question. I don't know.
Old 05-22-2008, 04:39 PM   #26
I'm beginning to hate having a turbo. It throws so much incertainty into the picture.
Old 05-22-2008, 05:06 PM   #27
Dont let the turbo bother you too much, it just makes it possible to extract more power from less engine.
A big plus is the boost guage which is basically a vacuum guage, with ability to show pressure, in positive or negative values.
This allows a greater sustained load on a smaller engine which should be more efficient.
The negative is it can also consume a lot of fuel quickly.
The best example I can think of was the 1.5 liter Alfa grand prix engine of 1950. 90 cubic inches 2 stage supercharging and 390 horsepower, at 2 MPG!.
Your turbo should only be used to sustain steep grades (or emergencies) if mileage is your priority. Other than that use the boost guage to try to maintain the lowest manifold pressure (close to 0) when you are pulsing in the highest gear you can use for your pulse. Gradually depress the gas pedal until you just reach 0 on your boost guage, then you will get a feel for your best pulse acceleration.
If you have to choose a lower gear or some boost use the boost. This would be up significant grades like those the big rigs can not maintain higher speeds.
For hypermiling avoid the turbo.
Use engine braking instead of friction braking because it shuts off all the fuel to your engine when the engine braking keeps the engine above about 1000 rpm. The savings can be significant if you can eliminate as much idling as practical without making everyone around you mad.
regards
gary
Old 05-22-2008, 05:13 PM   #28
Considering that a turbo reclaims lost heat energy from the exhaust gases when it is making boost it can be an overall efficiency enhancer, this is certainly true with a diesel.
Try making moderate boost at low rpm if you can without going open loop and rich. According to theory you should actually gain efficiency..
But then, in theory, theory and practice are the same while in practice they are not.
Zero a trip meter and then drive a predefined test loop with one technique..
Zero the meter again and try another technique..
You should be able to tell in a five mile loop if you are gaining or losing substantially with one technique or another. The longer you make the loop of course, the more accurate your results.
Old 05-22-2008, 05:15 PM   #29
But see, that's the other thing I don't understand. Are you saying on acceleration? That's usually my guide. I avoid boost if at all possible, which I can usually do very well. But are you saying that if I have a choice of accelerating with high vac verses close to none, I would get better FE? I somewhat understand pumping losses but on bal;ance, I seem to still be doing better at full vac.... Maybe it's just b/c keeping high vac gives me room to exceed my target and still stay on the negative side verses when I try to maintain no pressure I'm dipping into boost???
Old 05-22-2008, 05:18 PM   #30
fumesucker, to be honest, that's another thing I don't understand, closed/open loop? Can someone clear that up for me??? But otherwise, see what I said in my previous response, econ just seems to dip for me when I go into boost....
Saturn TDI for S-Series cfg83 Diesels 14 10-02-2007 01:24 PM
Anyone have experience making their own solar panels? MetroMPG Electric and Solar powered 17 08-29-2007 05:43 PM
Hovercraft 88HF General Fuel Topics 2 06-21-2007 10:41 PM
Belated Intro GasSavers_brick Introduce Yourself - New member Welcome 4 12-22-2006 06:48 AM
Atlanta Auto Show GasSavers_DaX General Discussion (Off-Topic) 26 05-07-2006 05:02 PM
