Google Earth info - Fuelly Forums
Old 06-23-2006, 10:51 AM   #1
GasSavers_Jack's Avatar
Google Earth info
I was just looking on google earth for elevations of my ride to check out all of my to work options. I didnt find anything better than my current one however I did find that my one EOC goes from an elevation of 1903 down to 799 over about 6 miles. Kind of funny because if I was looking over a 1200 foot cliff I would be sick but drive that everyday.
See my car here:
Old 06-23-2006, 11:53 AM   #2
Moderator
GasSavers_DaX's Avatar
Cool! But the return drive must SUCK going back up 1200 ft.
Old 06-23-2006, 12:18 PM   #3
Ya it kind of does but I like it alot better knowing I came down "for free"
See my car here:
Old 06-23-2006, 12:40 PM   #4
FE nut
diamondlarry's Avatar
This brings up a question I've had before. Does going up-hill cause more of a penalty than the gain you get from going down the same hill? Perhaps this is a good item for the experiments section? If so, how would you go about testing it?
2007 Prius,
Team Slow Burn
Old 06-23-2006, 01:11 PM   #5
95metro's Avatar
It would be tough to test on city "courses", but I think if enough runs were performed then you could at least deduce the benefits after figuring the margin of error between runs.
First you'd have to do a number of "normal driving" runs with no FE technique. Once you have a sufficient baseline established then you could try some FE technique runs and see how much gain you acheive down and up hill.
95metro is offline   Reply With Quote
Old 06-25-2006, 06:51 AM   #6
Moderator
Absolutely (in my mind). Anytime you transfer a form of energy, you have to figure in some kinds of loss. When you're going down a hill, you're transfering potential energy to kinetic energy, but you're also losing energy to drag and to tire friction (among other things). When you try to go back up the hill, you're still losing energy to the same parasitic losses.
Old 06-25-2006, 09:01 AM   #7
It works great if you get to coast down the hill at no fuel use and without braking to loose energy. Going up hill runs the engine at a higher load but not quite half the MPG of level driving and going down hill returns a much higher MPG generally.
Just setup the SGI in a Dodge Caravan V6 3.3 liter - the thing suck 0.5gph at idle!!!! My xB used 0.2-0.1gph for 1.5liters - holy cow!
Junk in the trunk Ziv General Fuel Topics 8 03-28-2012 12:59 PM
Mobile Site Suggestions Badams Fuelly Web Support and Community News 2 08-25-2011 11:13 AM
no average mpg bar graph for motorcycle models jonlon Fuelly Web Support and Community News 3 07-22-2010 03:59 AM
Topping it off screws my MPG piscataway Fuelly Web Support and Community News 2 03-04-2009 05:32 AM
More vehicle models EmptyH Fuelly Web Support and Community News 2 08-18-2008 07:13 AM
