Not only is every manufacturer different, every model and perhaps every car is different. This may sound stupid but I do it because I want to know: when I get a new-to-me vehicle I put a gas can with gas in the trunk and run 'er 'til she quits.
Then I know what the gas gauge readings really mean! For example, the old Tempo will go quite a long way past "E" before it runs out while on the newer Tempo, the instant the needle hits "E", you're done and you're walking. Every vehicle I have has been different in this respect, sometimes by a large margin. Also, by running it dry then adding a known quantity from the gas can, then filling up at a station, I know the true capacity of the system.
Now that is all on the "bottom end" of the range. The correlation at the top end varies too- on some the needle doesn't go much past "F" when "full" and on some it does. Evidently consistency and accuracy in fuel gauges is not a top manufacturer priority.
That said, I'm somewhat mystified by the whole topic of how much more can be forced in anyway. I suppose cramming a few more gallons in could be good in that it can reduce time, mileage, and potential spillage and evaporation losses from extra gas station stops somewhat- quite the opposite of the guys that like to run to stations constantly and top off or only run on a couple gallons at a time. Lug Nut:
10 gallons extra?!?
Sounds like a misprint somewhere along the line...
I guess I've had enough experiences with "old school" equipment to discourage "over" filling past the second or third click. The worst one was when the Coop fuel guy overfilled Pa's fuel barrel back on the farm; it was a hot day and the doofus filled the hot outside tank (with cool fuel from an underground tank) right to the brim. Shortly after he left I noticed fuel streaming out the fill cap and down the sides and the worst part was, everything on the place was full already; there was
nothing I could pump any gas into to relieve the expansion. Horrible, horrible waste. Scarred me to this day.
Also happens with old vehicles and equipment w/o evaporative control systems: fill too full when it's cool (best time for filling) and then it goes out the vent or the filler cap and onto the ground during the heat of day. Trauma!
And like psy, I've had the old Chevys with the early evap systems puke fuel too. It's even the same way with little stuff like lawn mowers- the vent caps aren't all that sophisticated, it's just a series of little baffles in there and if the tank is too full the heat and vibration of operation will send all the extra right out the vent.
In sum, overfilling seems a pretty pointless exercise to me. I just go second or third click at the pump, or nearly but not to the brim when using a gas can on small engines. Losing gas to spillage or evaporation is
not a gain.
