One day last summer, I decided to make some FE test runs so I drove about 6 miles to the station and filled up. I then drove about 25 miles or so and went back to the same station/pump and refilled. After squeezing as much gas as I possibly could into the tank, my mileage figured out to be way over 200 mpg. Apparently the fuel expanded enough to cause the mpg to be way off.
2007 Prius,
Team Slow Burn
