Gas mileage gains from 1967. - Page 2 - Fuelly Forums
Old 04-30-2008, 02:46 PM   #11
It's supposed to deform on brake application
sounds familiar...there are many deformed applications here @ GS.
Old 04-30-2008, 05:11 PM   #12
Originally Posted by bzipitidoo View Post
Then I have some words from a 60's auto manual. A sign that the engine is running too lean is that in addition to an uneven idle and a tendency to stall while idling, fuel consumption was TOO LOW! Ran just fine when not idling, though might not have quite as much power as it should. Yeah, not burning enough gas was a bad thing! The recommendation was to enrich the fuel mixture.
Remember though that valve seats weren't usually hardened back then and a lean mixture might easily burn a valve. Lead helped "high compression" 8:1 engines live compared to the pre-war 4:1 or 6:1 motors. Cast iron motors were also the norm, and while keeping heat in the chamber, dissipated heat very poorly from valve stems and pistons, particularly since they would have been backed up with unpressurised cooling systems.... and we wonder why 60,000 was a high mileage engine due for a rebuild back then...ahhh the good old days.
Old 04-30-2008, 05:26 PM   #13
GasSavers_SD26's Avatar
Originally Posted by Sludgy View Post
My Powerstroke Diesel has 3.73 gears........... This is the tallest gearset Ford offered! Actually, in 2004, nobody offered a diesel with less than 3.73 gears. Idiots.
E350's had 3.55's no problem. I'm confused.
Dave
Old 04-30-2008, 07:45 PM   #14
Cool
I thought we were talking about disc brakes?
Old 05-01-2008, 03:32 AM   #15
theclencher brings some appreciated humor to the sight, and i TRY to return the favor from time to time.
BTW, the original topic was '67 FE.
Hydrogen or H2O Systems 1Jal1 General Fuel Topics 4 10-11-2008 02:20 AM
Recent Fuel-ups Graph Scale rcsheets Fuelly Web Support and Community News 5 09-08-2008 04:11 AM
suggestion for stat comparison zahampton Fuelly Web Support and Community News 1 09-04-2008 08:29 AM
Current TV spot merckrx General Fuel Topics 1 08-14-2008 07:36 AM
