Fuel Economy Gauge? - Page 2 - Fuelly Forums
Old 06-01-2007, 04:17 PM   #11
Originally Posted by Matt Timion View Post
This isn't true. Yoshi (the inventor) found a magnetic sensor that you can attach to your axle in lieu of an electronic VSS that he said will work with the SuperMID.
Hopefully he can chime in here.
I think I found what you speak of. I read on this forum somewhere (cant find it now) that I need 4 pulses for every tire rotation. Is this true?
Also, can the Supermid be calibrated for different tire sizes?
Areodynamics is a problem for this truck for sure. Im thinking about taking the passenger side mirror off, as well as the roll bars off. Leaving the tailgate down does nothing, correct? A big drag for me is my 5 foot CB antenna. Its staying but I do have a spare 4 footer I might replace it with if I start doing alot of highway miles.
Bubba Bob is offline   Reply With Quote
Old 06-01-2007, 04:27 PM   #12
Matt Timion's Avatar
I will send Yoshi a message and tell him to answer your questions.
Old 06-01-2007, 04:30 PM   #13
Hey Matt, thanks but I just fired one off to him,
Old 06-01-2007, 06:35 PM   #14
Hi Bubba and all,
Thank you for your interest in my SuperMID and PM.
* fuel usage measurement
Please note that there are a lot of types fuel injection system.
http://en.wikipedia.org/wiki/Fuel_injection
The SuperMID measures the pulse width signal of one of fuel injectors.
- MPFI with high impedance injector works best.
- MPFI with low impedance injector needs special circuit.
http://www.gassavers.org/showpost.ph...4&postcount=16
- TBI with a single injector works good.
http://www3.telus.net/metro/mid.htm
- TBI with dual injectors does not work since SuperMID has only one onput.
(I think the each injector has different characteristic.)
- Continuous injection like Bosch's K-Jetronic does not work.
- Electric carburetor does not work.
- Diesel injectors does not work, I think.
ALrighty, I found a cheap eletric VSS. Its one that mounts magnets on the axle (I assume). It comes with four magnets. (judging by the picture) Is this what I need?
Link:
http://store.summitracing.com/partde...5&autoview=sku
I can't find any detail specifications about it, and can't judge whether it works or not.
* distance measurement
- recent Toyota and Honda vehicles have digital clean VSS signal.
- The standard is 4 pulses/rev of speedometer cable or 2548 pulses/km, or sometimes 4000 pulses/mile.
- We need special filter circuit for a mechanical switch VSS, which produces a chattering and noisy pulse, like installed on landspeed's Nissan.
- For those which does not have any VSS, I can supply mechanical switch VSS for Toyota, Nissan, Mitsubishi, Mazda and Daihatsu with the filter circuit.
http://www.gassavers.org/showpost.ph...9&postcount=17
Regards,
Yoshi
GasSavers_Yoshi is offline   Reply With Quote
Old 06-01-2007, 07:09 PM   #15
caprice's Avatar
Since you have TBI, you should have an electronic VSS. And just because your speedometer is mechanical, you still may have a VSS. My Caprice had a mechanical spinning cable that want to the speedometer, but it has a pickup that reads off the speedometer is the VSS.
David
85 Chevrolet. 30 MPG or bust!
caprice is offline   Reply With Quote
Old 06-01-2007, 07:15 PM   #16
Hmmm, I dont remember ever seeing threads on my VSS line. Ill check tomorow.
Do you have any info on that magnetic setup Matt mentioned?
Old 06-01-2007, 07:16 PM   #17
THanks Caprice. Ill look into that.
Old 06-02-2007, 08:24 AM   #18
I explained it on the post...
It is 4 pulses/rev and works with the SuperMID.
I don't know what kind of connecting thread standard Ford uses.
Yoshi
Old 06-02-2007, 03:13 PM   #19
Yoshi
Ah, didnt realize that was the magnetic setup. No, that deff. wont work. I was just told my truck has an electric VSS for the computer. Im about to look for that.
If my truck does have the electric VSS, will it even work since the supermid is designed for 2 times as many pulses as what mine probably will give? (according to a source, my should pulse 8000 per mile)
epa estimates cseverens Fuelly Web Support and Community News 2 06-09-2010 04:48 AM
Pulse and Glide? Pete7874 General Fuel Topics 24 02-26-2009 12:11 PM
