Fuel Additive - ether - Fuelly Forums
Old 04-21-2007, 10:25 AM   #1
Just received an email from a friend in Florida that met a guy very carefully adding ether to the gas in a Scion xB and getting 60mpg.
Anyone every hear of using ether to boost gas mileage - I know it increases performance and can produce pink exhost smoke - at least it used to in the old days when leaded gas was popular.
Old 04-21-2007, 11:54 AM   #2
ELF
ELF's Avatar
I have not heard of anyone using it. But I often wondered how or if it would help mpg. I just assumed it would evaporate before it got used.
Old 04-21-2007, 12:23 PM   #3
GasSavers_Ryland's Avatar
I know that my little diesel modle air plane engine is suposed to run on a mix of caster oil, kerosen, and ether, but never heard of someone useing it in gasoline.
Old 04-21-2007, 12:40 PM   #4
zpiloto's Avatar
Where can you even get ether and how much does it cost and at what ratio?
Old 04-21-2007, 01:13 PM   #5
trebuchet03's Avatar
starting fluid
but the question is... what kind of ether is being added? There's a few out there.... at least one of which is already used in gasoline to
11/12
Old 04-21-2007, 10:50 PM   #6
Hockey4mnhs's Avatar
isnt that a drug? fear and loathing in las vegas anyone?
Old 04-21-2007, 10:59 PM   #7
Send a message via AIM to eivad1 Send a message via Yahoo to eivad1
why didnt he tell u what it was
eivad1 is offline   Reply With Quote
Old 04-21-2007, 11:06 PM   #8
duh my bad, what is ether made of and how much would u put in
Old 04-22-2007, 02:57 AM   #9
Nope and I doubt I will find out but it is more controlled because of the use of it to produce drugs - probably a good start would be starter fluid in a spray can. Used to start diesel engine in cold weather often and known to blow them up.
Old 04-22-2007, 11:44 AM   #10
ELF
ELF's Avatar
I just did a run with the sable today with ether. I went to the gas station and got some starting fluid. 10 oz. can for 1.98 I held the can upside down and pressed the nozzle to let all the air out. then I punched a hole in the top of the can and poured it into a container. then used a funnel and poured all of it in my tank. I figure I had about 10/11 gal in tank so about 1 oz. per gal.
The trip to my mothers, 55 miles each way mostly north/south. 85% hwy 15% city
North 38mpg
south 35.9 mpg...... average.. 36.95 mpg. lots of traffic on the way home.
This is by far the best mpg I have got on this trip. I take this trip maybe 2 times a month for years, my best ever previous was 34.5 average.
So does the Ether work? It looks promising, But I need to do more testing.
some of you guys should give it a try and post your results.
What is this stat? cavale Fuelly Web Support and Community News 1 09-03-2008 08:23 AM
