Found another way to save on gas. - Fuelly Forums
Old 03-15-2006, 07:19 AM   #37
krousdb's Avatar
Re: hate to revive this old
Originally Posted by MetroMPG
hate to revive this old debate, but i believe i have found some solid support for the issue of PSI and tire diameter/circumference.
more air pressure DOES slightly change the diameter of a tire.
Hmmm. I'm not convinced that you can make that conclusion from the source you quoted. I would have agreed with you if you had said:
"more air pressure added to an underinflated tire DOES slightly change the diameter of a tire." I agree because the steel belts and sidewalls may not be fully tensioned when underinflated. But i see nothing in the quote that says that adding air pressure to a properly inflated tire changes the diameter. I know that i am splitting hairs here but I like to do that.
Country/Currency Preference pb Fuelly Web Support and Community News 1 10-29-2008 06:27 AM
Experimenting with a new route to work krousdb General Fuel Topics 5 03-18-2006 08:58 AM
