Ford Ranger (1995) obd 1 guage - Fuelly Forums
Old 08-01-2008, 08:02 AM   #1
Is there any tool/device that i can use to get real-time fuel consumption? Obviously a scan guage won't work.
I've been getting around 8.0L/100km to 8.5l/100km (sorry i'm canadian) so i'm really happy with my mileage so far but just want to improve on it a bit.
Thanks guys.
ryandpotter is offline   Reply With Quote
Old 08-01-2008, 08:21 AM   #2
You can get realtime fuel consumption somewhat easily -- this tells you how much fuel you're using but does not divide it by speed to tell you how far you go on that fuel. Getting realtime fuel economy (l/100km) may be more difficult.
Take a look at the DIY fuel rate meter link in my sig. In that post there's links to a couple other ideas too. It's useful for many (but not all) of the same purposes as a realtime fuel economy readout and a tells you a couple things that a fuel economy readout wouldn't.
Old 08-01-2008, 08:34 AM   #3
I don't mind figuring out my economy when i fill up, If i knew the realtime consumption though I'd be able to better manage my driving style to decrease the same right?
Old 08-01-2008, 08:43 AM   #4
Yup. Fuel rate easily tells you the difference between two options at a given speed -- for example, choosing which gear to use at 40mph. It also tells you when you've triggered DFCO. It's not quite as useful for deciding whether to go faster or slower since it just tells you fuel rate, not economy.
Specifically, it tells you the injector's duty cycle (percentage of time it's open). With a little bit of research and arithmetic you could make it into liters per hour, though that's not really a worthwhile way to use it; instead you just compare numbers on the meter.
The amazing gas mileage blunder Matt Timion General Fuel Topics 56 09-09-2010 11:54 PM
Injector kill switch for Autos cwa Transmissions and Running Gear 17 10-09-2009 10:37 AM
Things To Look For When Buying A Civic Vx??? panamacolin General Fuel Topics 10 08-15-2008 04:57 PM
P&G Questions dosco General Fuel Topics 25 05-02-2008 01:46 PM
passwords fixed Matt Timion Fuelly Web Support and Community News 3 05-20-2006 09:34 PM
