Finally: MPFI and OBD1 Swap Completed - Fuelly Forums
Old 04-09-2006, 02:35 PM   #1
This is basically a bragging thread. Did all the work myself, even the wiring, oh no! Even the ecu chipping, !
Here's my OBD1 ecu that I chipped and never put a case on, I tell people not to kick it but other then that I don't give a damn.
WTF! My first engine shot ever!
Close up of the intake manifold and ****. I'm still using stock 240cc injectors, will swap them soon to the CX/VX 190cc injectors.
Wrong throttle cable bracket, barely holding on!
Kickdown cable? Where's that go? :P
The clamp making the intake arm think it's 16mm smaller than it is, 40mm TBs are the ****.
Hacked off the end of my intake box to barely fit this thing on.
But most of all, it's done! 35.6 MPG with a rather severe vacuum leak, hoping to be up there with it fixed, and it's still an auto!!!
Old 04-09-2006, 04:35 PM   #2
****, now I still have
****, now I still have surging idle at warm up, dunno where to start working on that, any ideas? It's not like I ever idle during warmup, but still.
Old 04-09-2006, 04:57 PM   #3
Send a message via AIM to molecule
idle surge is either a vac
idle surge is either a vac leak,IACV,ir FITV
since you mentioned startup...could be the FITV
though it doesn't directly cause surging
it is a piece of wax heated by coolant...when the car warms up it closes off the port reducing air bypass...and lowers the idle...
probably a vac leak...did you use a new intake mani gasket...?
typical to have a leak there...
check all your vac hoses for cracking
take off your IACV and clean the screen
also cx/vx injectors are 240cc
the 190cc injectors were on the obd2 hx motor and maybe the y7 cx...
you would have to splice in the obd2 clips to use those...
and the gains would probably eliminate themselves due to the function of the o2 sensor compensation...
also i have an ecu cover to send you...
its not worth risking a spilled drink etc on ruining your ecu and a ruining car dude...
BE ZEITGEISTED
molecule is offline   Reply With Quote
Old 04-09-2006, 05:00 PM   #4
krousdb's Avatar
COngrats on the swap! I
COngrats on the swap! I expect some competition from you now.
Sorry I can't help with the surging idle thing. If I had that problem I would ask you what to do.
Old 04-09-2006, 05:02 PM   #5
I have no iacv. Also, I previously had a vacuum leak from the bad pcv, but I no longer do, this is only during startup. The iacv is fine also, I have cleaned the hell out of it and it was sent from jared with it working.
I did. I have also sprayed carb cleaner in every reasonable spot to verify it isn't sucking it in. Also, with the pcv leak going block that and the iacv it died, not getting air from anywhere else.
I swear they are 190cc, and the idea is for a finer spray pattern, I will adjust the chip accordingly to say they are 190cc.
Old 04-09-2006, 05:02 PM   #6
I won't be competing with
I won't be competing with you until I'm manual. I'll talk to disco about it later and see what he has to say.
Old 04-09-2006, 05:14 PM   #7
you have an IACV i can see
you have an IACV i can see it in the pictures...
its on all intakes
if you mean it isn't hooked up then you will throwing codes on your computer and is DEFINATELY the reason you are surging...
the hunting is cause by something...
its merely being missed or a faulty component...
what ecu are you running...?
if its chipped then what stock map did you use and what program (uber or crome)
peace
BE ZEITGEISTED
Old 04-09-2006, 05:15 PM   #8
EDIT: I have no FITV,
EDIT: I have no FITV, sorry.
It's hooked up and fine, when I had it unhooked it didn't surge anyway.
Crome, P06 map, disabled o2 heater.
Old 04-09-2006, 05:21 PM   #9
burn a new rom and play with
burn a new rom and play with the iacv duty cycle in options
see if that changes it
BE ZEITGEISTED
Old 04-09-2006, 05:24 PM   #10
Got any suggestions on how
Got any suggestions on how to do such? It idles awfully high during warm up also, so I think I might need to fudge around with the ECT compensation also.
