Finally broke the 100MPG segment - Page 2 - Fuelly Forums
Old 10-12-2006, 07:23 PM   #11
9999mpg
Originally Posted by LxMike
i saw over 200 once on my scanguage!
was coasting down from 55mph though!
When I key-off to CODFISH, the Scanguage shows 9999mpg then turns off.
Old 10-12-2006, 07:42 PM   #12
On my first generation ScanGuage, setting it to "hybrid" allows it to stay on when I key off the TL.
hawkgt647 is offline   Reply With Quote
Old 10-12-2006, 07:53 PM   #13
Hmmm.
Hmmm...I have the first gen also...I'll look for the hybrid function...
Old 10-13-2006, 05:04 AM   #14
hmmmm i'll have to try that. mine is with engine running... no hills down here to coast for too long though so i just coast up to the red light then key off. on my car i have to put it in park to restart
Old 10-13-2006, 05:08 AM   #15
It's likely just a switch in the shifter mechanism. Find it and you could probably mod it pretty easily so you could start in N (or whatever gear you want... careful!).
Old 10-13-2006, 07:25 AM   #16
I was wrong! i guess i still had car in drive. just went out and tried with shifter in neutral and it started fine.
I have found that i can key off and back on again and S.G 2 still holds current measurements. just have to watch the oposite light so i can be ready to restart when light are changing. but usualy have plenty of time since i'm hardely ever first in line.
Query with fill ups Dukey Fuelly Web Support and Community News 3 04-09-2010 02:27 AM
The Condensator: Just a PCV Jar? SVOboy General Fuel Topics 10 11-07-2007 04:08 AM
