Filled up regular gas by accident - Fuelly Forums
Old 02-27-2013, 11:30 PM   #1
Just filled up, and they gave me regular when I asked for premium. Should I run the regular gas down before I refill, or run it to half the tank to diffuse the regular gas with the premium my engine recommends?
woodysweats is offline   Reply With Quote
Old 02-27-2013, 11:43 PM   #2
Member
Does your car require premium for some reason?
dtwjr is offline   Reply With Quote
Old 02-27-2013, 11:48 PM   #3
Member
If it does, don't sweat it. Just start putting premium in it from now on.
Old 02-28-2013, 01:51 AM   #4
yeah, my manual says 91 octane or better... i'm not too worried about it... i used to put midgrade in regularly... but just wondering if anyone had any tips or thoughts...
Old 02-28-2013, 03:27 AM   #5
BDC
It depends on the engine. You would get much better information if you looked on a site or forum specific to your car. I have no experience with the Toyota 2ZZ engine specifically but it being a modern engine with knock feedback, I would assume it would be fine to do as long as you don't drive the motor hard.
BDC is offline   Reply With Quote
Old 02-28-2013, 07:58 AM   #6
Being the 2zz engine the effects will be minor on your engines since its only one fillup... Dont hit lift during this tank and probably shouldnt rev over 3k rpm until you get a full tank of premium in..... You can also buy a bottle of STP octane booster to help your regular gas run a little better.
2013 Mazda 3 GS-SKY 6MT (Current)
2015 Mazda 3 Sport GX 6MT (Lease return)
2013 Mazda 3 Sport SKY-SKY 6AT (Ex's daily driver - totalled)
2007 Toyota Matrix Base 5MT (Sold)
MatrixDom is offline   Reply With Quote
Old 02-28-2013, 09:09 AM   #7
Member
I second the octane booster. If you are that worried and just put some in and shake the car as best as you can.
Ciderbarrel is offline   Reply With Quote
Old 02-28-2013, 10:43 PM   #8
Member
"...shake the car as best you can." Cute.
Old 03-04-2013, 10:42 PM   #9
I also would suggest the octane booster if your owner's manual requires the 91 octane. As BDC points out your onboard computer should have a knock sensor that will retard your ignition timing, alter your fuel mapping, possibly change your valve settings if your engine application has that option any one of which will affect your engines performance but should protect it from potential damage from using a lower than specified octane rating. A bottle of Octane booster from your local auto parts store shouldn't be too costly, pick one up, add the amount recommended for the amount of 87 octane that was added at that fuel up and top it off with 91 to mix the booster into the tank and you should be fine.
Old 03-11-2013, 01:16 PM   #10
Octane booster
07grizz is offline   Reply With Quote
